 Post subject: PCB's inflating Reallocated Sector
PostPosted: April 19th, 2018, 8:57
PCBs of ST1000DM003 had fried. but it's working properly. Everything's fine.
Boot 0x40M
Spin Up
TCC-0018[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0018
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 000083C1
[RSRS] 040A
Reconstruction: Completed 1:
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00000041
MCMainPOR: Feature Enabled...
PowerState = IDLE1
I intend to swap this pcb. Donor drive was st2000dm001. this drive corrupted itself.
viewtopic.php?f=1&t=36653
after the swap, drive comes up. But it freezes pc somehow. Reallocated sector count was 280 at the beginning.
but it rises 2000 --> 8940--> 10456
the terminal message changed.
Boot 0x40M
Spin Up
TCC-001F[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-001E
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 000084D9
[RSRS] 0512
[MCMTWS]
(DOS)STE OGHT: 0x0000000007C4B9A0 - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004E
(DOS) Refresh Start.
(DOS)ABT Count 004E
(DOS)STE OGHT: 0x0000000007C4BE65 - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004E
(DOS) Read Error - 43110081
InitiateMarkPendingReallocateRequest for disc_lba: 0000000007C4C964!.
(DOS)ABT Count 004E
Dither!
(DOS)STE OGHT: 0x0000000007C4CCB4 - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004E
(DOS)ABT Count 004E
(DOS)STE OGHT: 0x0000000007C4CFE2 - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004E
(DOS)ABT Count 004F
Dither
(DOS)STE OGHT: 0x0000000007C4E2F6 - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004F
(DOS)ABT Count 004F
(DOS)STE OGHT: 0x0000000007C4E48D - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004F
(DOS) Refresh Start.S23(01)
(DOS)ABT Count 004F
(DOS)STE OGHT: 0x0000000007C4E7BB - 0x0000000007C4EAE8 - 0x00023D15 - 0x00023D33
Count 004F
(DOS)CMP Count 004F
(DOS)STE OGHT: 0x0000000007C43A70 - 0x0000000007C46BB8 - 0x00023CC5 - 0x00023CE3
Count 0053
InitiateMarkPendingReallocateRequest for disc_lba: 0000000007C43C6E!.
(DOS)ABT Count 0053
ASCII Diag mode
I regret that.
i revert back to 0 point.
clear smart but Temp is 251 C.
i clean the original pcb. restart Pc. everthing's fine with fried PCB.
Why is this swap unsuccessful? is donor Pcb faulty?
another attempt was successful. i use st2000dm001's PCB for st1000dm003 last month.
 Post subject: Re: PCB's inflating Reallocated Sector
PostPosted: April 19th, 2018, 9:42
I don´t understand what you mean, but
If you have one pcb working fine, then use it to recover the data from the disk then trash it.
PostPosted: April 19th, 2018, 10:06
st1000dm003 is o.k but pcb is fried. i want to change PCB.
st2000dm001 is donor for PCB. it has head issue.
swapping PCB increases Reallocated Sector Count 280 to 10254 in 1 hour.
PostPosted: April 19th, 2018, 10:46
If that pcb with the missing pins if fine, and the hdd works fine with it, can´t you just replace the connectors ?
PostPosted: April 19th, 2018, 12:07
is it harder than replacing 4 legged chip?
PostPosted: April 19th, 2018, 15:37
Spildit wrote:
Changing PCB will NOT make any diference on the S.M.A.R.T. values that are already increased ....
You can't expect to "fix" the sectors that are now on G-List by swapping PCB ...
no, it did.
RSC (Reallocated sector count) is 280 for 2 years..(3,3V area's burnt) No increase with burned PCB.
Donor PCB inflate it . it rises continously...it exceed 10.000 within 1 hour.
i revert back burned PCB and problem's gone.
PostPosted: April 19th, 2018, 16:08
If you don´t have a good pcb ( one that works correctly ) then it is easier to replace the connector then to keep searching for another pcb.
PostPosted: April 19th, 2018, 16:47
Could there be an adaptive mismatch arising from some variation in the read channel within the MCUs ???
PostPosted: April 19th, 2018, 18:24
Or the second board isn´t working so correctly.
PostPosted: April 30th, 2018, 4:17
I've changed plastic connector.it took app. 2 hours. desoldering and resoldering.
first time I melt a plastic of donor .
at second attempt using Aluminium foil was successful.
PostPosted: April 30th, 2018, 9:00
Ok, good it worked.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 160 guests
