 Post subject: WD800BB PCB swap to recover data
PostPosted: April 20th, 2018, 4:22
Hi all
i have broken pcb on my hdd
is Western Digital WD800
MDL: WD800BB-22JHCO
DCM: HSBHNTJAH
PCB board is: 2060-701292-000 rev a ( white sticker: 2061-701292-00 AP)
i found donor:
MDL: WD800BB-22JHCO
DCM: HSBHCTJCH
is just diffrent DCM. model, pcb same.
when i change u12 (bios) it will work to recover data?
best regards
 Post subject: Re: WD800BB PCB swap to recover data
PostPosted: April 20th, 2018, 4:54
Should work
PostPosted: April 20th, 2018, 5:01
If i`ll find same hdd ( same model, same dcm, same pcb) i still need to swap u12 rom from my broken drive to donor pcb?
PostPosted: April 20th, 2018, 7:47
Yes, you do
PostPosted: April 20th, 2018, 9:14
some times you can get lucky, and you'll not have to transfer the U12
PostPosted: April 20th, 2018, 14:46
This is true, especially if the DOM is close.
If if clicks with new PCB then you have other issues.
If it spins up and stays spinning but with no ID then you’ll need to switch U12 and it should work.
PostPosted: May 30th, 2018, 14:48
That's my first post so hi everyone :D
I have the same problem so I won't create a new topic.
Patient:
WD Caviar SE WD800
MDL: WD800JB-00JJA0
DCM: HSBHYTJAH
PCB 2060-001292-000 white sticker: 2061-001292-A00 AD
Not running, not visible in BIOS
Donor:
WD Caviar SE WD800
MDL: WD800JB-00JJC0
DCM: HSBHNTJCA
PCB 2060-701292-002 white sticker: 2061-701292-A00 BB
HDD is fine.
When I swap the PCB patient starts running but stops after a few seconds. Should I change U12 or PCBs are not compatibile?
Thanks for your help in advance.
Users browsing this forum: Google [Bot] and 77 guests
