 Post subject: Kingston SUV400S37/240G UV400
PostPosted: March 5th, 2018, 8:23
Really is crazy, tru any but can resolved.
some experience with this?
 Post subject: Re: Kingston SUV400S37/240G UV400
PostPosted: March 5th, 2018, 10:27
Kingston SSD's are rubbish. out of around 120 I've had at least 5 that have died while installing OS.
You don't say much but I'm guessing you want DR. The Marvell controller hasn't got much support for Chip-off at least. What's the issue with drive? What have you tried? does it power up?
you might want to upload pic of other side as well.
PostPosted: March 5th, 2018, 12:13
Problem:
- No acces to data
- No run
Another Pic:
PostPosted: May 4th, 2018, 16:56
One of these just landed on my desk and I'm thinking it might be the exact same issue...though, tough to determine based on the OP's comments. The SSD comes ready and IDs like it is working, yet not a single sector can be read.
PostPosted: May 4th, 2018, 18:44
I would have tried to help with test points, but the OP's photos were unusable.
(Why do people think that the markings on chips are unimportant? What information can one discern from a black rectangle?)
PostPosted: August 14th, 2019, 11:08
Got one with the same symptoms... I have not much hope for it at the moment... :s
Chip-off recovery is out of scope i guess...
it would take considerable amount of time to reverse it, so better leave it for now.
PostPosted: December 19th, 2023, 17:19
Hello!
Could someone help to find safe mode and terminal contacts for this kind of board?
Thank you!
PostPosted: December 19th, 2023, 18:01
Try shorting the NAND Ready/Busy* pin to ground. It works for some SanDisk SSDs ...
PostPosted: December 20th, 2023, 7:53
Thank you Frank, BUT...because the controller chip is Marvel 88SS1074, it has TWO shorting pont for safe mode.
For recovery also i need terminal soldering points.
For reference:
https://blog.acelab.eu.com/pc-3000-ssd-sandisk-ultra-ii-and-wd-blue-marvell-cpu.html
