 Post subject: Samsung HD320KJ No Power at all in the Hard Disk.
PostPosted: May 8th, 2018, 6:15
Hello there,
I have Samsung HD320KJ Hard Disk. It has Spinning problem. When put on the system, after some time PCB and Hard Disk get Heating, but not spinning at all. i attach pcb diode reading. Please help me. It has valuable data in it.
 Post subject: Re: Samsung HD320KJ No Power at all in the Hard Disk.
PostPosted: May 8th, 2018, 10:07
By the sticker in it, was it from an HP system ? How did the problem started ? Could be something PUIS-related, but waif for some other people to comment on that.
The readings on the diodes near the ram chip doesn´t make much sense. Please, measure continuity in them, both ways, with the hdd disconnected from power.
Also, does the motor controller gets hot ?
PostPosted: May 8th, 2018, 10:33
Thank you Sir for ur kind reply.
MCU and Motor Chip got Hot enough. but only motor is not running.
Attch pic of continuity measure.
PostPosted: May 8th, 2018, 11:26
The measurements still seem wrong. But if the motor controller is gettin hotter than normal, them possibly it is damaged.
You will probably need to find another board with the same code and preferrably the same firmware version. The code below the number "1" at the left side of your picture.
PostPosted: May 8th, 2018, 14:27
Thank you sir, In India i did not find any exact donor drive. so i moved to this forum. In other hand motor chip in hotter normal.
anything else you may suggestion, you are welcome sir.
thank you.
PostPosted: May 8th, 2018, 14:31
Spildit wrote:
1 - Can you plug the drive to a TTL and check if it produce a LOG ?
http://www.hddoracle.com/viewtopic.php?f=46&t=192
http://www.hddoracle.com/viewtopic.php?f=116&t=189
2 - Can you ear ANY NOISE at all from the drive like sounds of it trying to spin ? Any sound of head movement ? DO NOT OPEN THE DRIVE LID.
3 - If you can't ear any sound and if you can't get any terminal LOG just BUY a PCB from another drive of the exact same model with exact same firmware.
You do have firmware version on the LABEL so get a drive like yours - HD320KJ/C with firmware CP100-12 and you don't need to move any ROM or adapt any firmware overlay, just swap the PCB and you are done.
If you do get terminal log and some messages about PRE-AMP then the damae is internal and the drive doesn't spin up because of damage to pre-amp.
If pre-amp is shorted you might not be able to get terminal output as well even if PCB is good. You can try to get the log by insulating head contacts to see if you can get message of invalid pre-amp.
Regards.
1. i haven't any ttl adopter. i will buy tomorrow and post log here.
2 i didn't hear any sound from inside of the hard disk. only pcb get hot only.
3. In india i haven't find same exact drive so that i moved hear for help.
Thank you sir.
PostPosted: May 8th, 2018, 15:35
No 12V power is getting to the PCB. That's because there is a missing polyswitch. If the PCB is otherwise OK, just replace the polyswitch with a wire link (or picofuse).
PostPosted: May 8th, 2018, 15:51
The motor controller looks discoloured.
PostPosted: May 8th, 2018, 17:03
Spildit wrote:
I would just replace the PCB ...
If this was a data recovery case that i was working on i wouldn't even bother as the FW version is stamped on the label and i would just buy a replacement (PCB) on eBay and that would be it.
The OP is in India. Just for perspective ...
India’s cheapest smartphone Freedom 251 launched at Rs 251 (US$4):
https://www.gadgetsnow.com/mobiles/Indias-cheapest-smartphone-Freedom-251-launched-at-Rs-251/articleshow/51020750.cms
PostPosted: May 9th, 2018, 0:51
you are right fzabkar. i removed polyswitch because of it had a problem. with faulty polyswitch, system did not start. i removed polywitch and connect hdd system start but no vibration or any known sound output from hdd. if i replace this polyswitch with good one will hdd start in normally? and i want to tell that without polyswitch switch all chips on the hdd got hot.
PostPosted: May 9th, 2018, 1:02
@zaidkagzi47
Need to ask. Is this your drive, or are you doing recovery for someone else?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 9th, 2018, 1:15
digisupport wrote:
@zaidkagzi47
i am doing data recovery sir
PostPosted: May 9th, 2018, 4:20
Why would you think that an electronic device would continue to function after removing a fuse?
PostPosted: May 9th, 2018, 10:37
You removed the wrong component. Search this forum for TVS , and you will find a lot of information.
Basically, put back the poliswitch and replace the TVS diodes, after you have searched and read the other threads.
PostPosted: May 9th, 2018, 17:45
I agree with you, replacing the pcb is the easier way for him.
Users browsing this forum: Google [Bot] and 199 guests
