 Post subject: hitachi arm massive bad sectors just in one head area
PostPosted: May 14th, 2018, 12:46
Hi
Heads clean and working perfect with all heads on donor drive,platter looks good,this errors also if I load PSHT RDMT virtual translator.
User said it's happened in second no falling or hit to disk,the bad sectors it's all over one head area from beginning to end,what is the logic here ?
Does those bad sectors can be recoverd with no corrupted files ?
 Post subject: Re: hitachi arm massive bad sectors just in one head area
PostPosted: May 14th, 2018, 13:01
Hi ,
Which head is this .How many platters are there in this drive ?
PostPosted: May 14th, 2018, 13:48
Head 0 from two platters,I had another hitachi drive with the same symptom with this drive I took the platters out and it was seem good so I guess it's a common problem.
Users browsing this forum: No registered users and 154 guests
