 Post subject: wd40ezrz-00wn9b0 my book mac encrypted
PostPosted: May 23rd, 2018, 21:49
I have a wd40ezrz-00wn9b0 my book mac, mirrored 100% either via pc 3000 decypt/encrypt with SED disabled or enabled as well as using original usb enclosure. Tried all the combinations. I can see some partitions with Garbage partition labels. Only about 7000 files raw recovery, all seem corrupted, sector 0 and 1 seem normal. Connected Mac, no password required. Is it because APFS? Client did not set a password. Any suggestions are appreciated.
 Post subject: Re: wd40ezrz-00wn9b0 my book mac encrypted
PostPosted: May 24th, 2018, 18:08
Maybe it's APFS encrypted partition or HFS encrypted with FileVault.
If is FileVault encrypted then follow this guide:
https://derflounder.wordpress.com/2011/ ... oot-drive/
but first you should do a double clone due to changes that will be applied directly on partition structure by following the guide.
My firmware database:
Users browsing this forum: Majestic-12 [Bot] and 67 guests
