Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Chip Off jobs on encrypted Android Phones
PostPosted: May 30th, 2018, 20:31
Thank you both. I have set this up several times over the past few weeks and probably got a little sloppy (or frustrated) when I was setting this up this last time. I will redo the terminal access and report back.
Many thanks.
PostPosted: May 30th, 2018, 20:36
AIUI, /dev/disk0s1s2 is the partition that contains the user's data. Either it is not being mounted correctly, or the partition is damaged.
I see some Internet references which suggest mounting /dev/disk0s1s2 to /mnt1/var rather than /mnt2. That should at least tell us whether there is something wrong with the mount point, or so I think.
If the partition is damaged, I would be looking for a way to "dd" the raw partition data to another storage medium. Perhaps there is such a tool in the OS?
PostPosted: May 30th, 2018, 20:58
Please, can you post the contents of mount.sh
Also, maybe trying to issue a comand of dd --help to see if it is present.
If not present, maybe it could be compiled in other place then transferred to the phone.
PostPosted: May 30th, 2018, 21:02
I'm wondering if the data on the second partition are encrypted, and whether the partition needs to be mounted by the OS before the OS can decrypt it. If so, then a raw image may not be useful.
PostPosted: May 30th, 2018, 21:24
Maybe.
The commands in the mount script may show some light in this.
Also, depending on how/where/by who the partition is encrypted ( if it is ) a raw dump of it could be decrypted outside of the device.
But lets first take a look at that script. Maybe a simple command is missing in it.
PostPosted: May 31st, 2018, 14:08
I have copied a new terminal outputs below. A general one and the dd --help. I am not sure how to complete some of the steps you have detailed.
How do I run 'commands in mount script'?
mount.sh does see both partitions, but errors at mounting the HFS partition.
How do I mount /dev/disk0s1s2 to /mnt1/var rather than /mnt2?
The initial part of the terminal log is after entering 'device_infos', that part id what makes me thing the user data area might be encryted.
ssh -p 2022 root@localhost
root@localhost's password:
Permission denied, please try again.
Use mount.sh script to mount the partitions
Use reboot_bak to reboot
Use 'device_infos' to dump EMF keys (when imaging user volume)
-sh-4.0# device_infos
iphone data protection tools: http://code.google.com/p/iphone-dataprotection
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
   <key>DKey</key>
   <string>8caf31327c741978cd6654c2615b835d8687d83ab866b93d4b766eda61158979</string>
   <key>ECID</key>
   <integer>3429012415310</integer>
   <key>EMF</key>
   <string>c94261c13c39df3b49fc0d8a7975aded7bfa4906013e591fb12f8ab814babfd6</string>
   <key>btMac</key>
   <string>40:a6:d9:ca:ad:a2</string>
   <key>dataVolumeOffset</key>
   <integer>147456</integer>
   <key>dataVolumeUUID</key>
   <string>9b6b1598feca7c07</string>
   <key>hwModel</key>
   <string>N90AP</string>
   <key>imei</key>
   <string>012535008910292</string>
   <key>kern.bootargs</key>
   <string>rd=md0 nand-enable-reformat=1 -progress </string>
   <key>key835</key>
   <string>8259eb872d6e03fc3da08494d81c1772</string>
   <key>key89A</key>
   <string>d651c9460d733bc4400874314b139018</string>
   <key>key89B</key>
   <string>640937cad3eb10f61f13adce58caf36b</string>
   <key>lockers</key>
   <data>
   a0w0ADFHQUIxR0FCUt7SirXKiHEzkEbk5ar41dN8fxOxePt6RSXMk6ceAE2mvyKdl2M0
   74UbxppuYncga0xQAE1Wd0zxqAUadTiv6wB4N2IHFzwgnlOFQEUtg0V4F+Z9wpp0xPgW
   Pa88aB93uqJlECeCyT7ZXj3BK/DAMLSs8Dsq5AtJEs2t1a5mK+sTcKpIIFBd/2tMKAB5
   ZWvEhKwQGMoDxTDuRoFSmXx0yFRWVXo66arp3tmf8WFn1xkfI7ZS00lhqmtMAABFTk9E
   AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
   </data>
   <key>nand</key>
   <dict>
      <key>#block-pages</key>
      <integer>128</integer>
      <key>#bootloader-bytes</key>
      <integer>1536</integer>
      <key>#ce</key>
      <integer>4</integer>
      <key>#ce-blocks</key>
      <integer>4100</integer>
      <key>#page-bytes</key>
      <integer>8192</integer>
      <key>#spare-bytes</key>
      <integer>448</integer>
      <key>banks-per-ce</key>
      <integer>2</integer>
      <key>bbt-format</key>
      <integer>1</integer>
      <key>boot-from-nand</key>
      <data>
      AQAAAA==
      </data>
      <key>device-readid</key>
      <integer>848619416</integer>
      <key>dumpedPageSize</key>
      <integer>8212</integer>
      <key>is-bfn-partitioned</key>
      <true/>
      <key>meta-per-logical-page</key>
      <integer>12</integer>
      <key>metadata-whitening</key>
      <data>
      AQAAAA==
      </data>
      <key>name</key>
      <data>
      ZGlzawA=
      </data>
      <key>partitions</key>
      <dict>
         <key>Boot Block</key>
         <dict>
            <key>Block Count</key>
            <key>Block Offset</key>
            <integer>0</integer>
         </dict>
         <key>Effaceable</key>
         <dict>
         </dict>
         <key>Filesystem</key>
         <dict>
            <integer>4084</integer>
            <integer>16</integer>
         </dict>
         <key>Firmware</key>
         <dict>
            <integer>8</integer>
         </dict>
         <key>NVRAM</key>
         <dict>
            <integer>6</integer>
         </dict>
      </dict>
      <key>ppn-device</key>
      <false/>
      <key>use-4k-aes-chain</key>
      <data>
      AQAAAA==
      </data>
      <key>valid-meta-per-logical-page</key>
      <integer>10</integer>
      <key>vendor-type</key>
      <integer>1376273</integer>
   </dict>
   <key>ramdisk compile time</key>
   <string>Jul  9 2012 23:31:09</string>
   <key>ramdisk revision</key>
   <string>8c6b79b04374</string>
   <key>serialNumber</key>
   <string>88049GK9A4S</string>
   <key>udid</key>
   <string>4f734d8fd9960c0ecff1d7fd85ebc1c0719ae093</string>
   <key>wifiMac</key>
   <string>40:a6:d9:ca:ad:a3</string>
</dict>
</plist>
-sh-4.0# ls
-sh-4.0# ls /
System   bin  dev  etc  mktar.sh  mnt1  mnt2  private  sbin  usr  var
-sh-4.0# mount
/dev/md0 on / (hfs, local, noatime)
devfs on /dev (devfs, local, nobrowse)
-sh-4.0# mount.sh
Mounting /dev/disk0s1s1 on /mnt1 ..
Mounting /dev/disk0s1s2 on /mnt2 ..
mount_hfs: Invalid argument
-sh-4.0# ls /mnt2/
-sh-4.0# ls /mnt1/
Applications  Library  User  boot   dev  lib  private  tmp  var
Developer     System   bin   cores  etc  mnt  sbin     usr
-sh-4.0# ls /mnt1/User/
ls: cannot access /mnt1/User/: No such file or directory
-sh-4.0# ls /mnt1/Library/
Activator        Frameworks      Managed Preferences  Printers
Application Support  Internet Plug-Ins   MobileDevice        Ringtones
Audio           Keychains      MobileSubstrate      Updates
Caches           LaunchAgents   PreferenceBundles    Wallpaper
Dictionaries        LaunchDaemons   PreferenceLoader
Filesystems        Logs      Preferences
-sh-4.0# ls /mnt1/Library/MobileSubstrate/
DynamicLibraries  MobileSubstrate.dylib
-sh-4.0# ls /mnt1/Library/MobileSubstrate/DynamicLibraries/
Activator.dylib       PreferenceLoader.dylib  TetherMeCC.dylib
Activator.plist       PreferenceLoader.plist  TetherMeCC.plist
EDGEEditPermit.dylib  SBSettings.dylib         TetherMeMIS.dylib
EDGEEditPermit.plist  SBSettings.plist         TetherMeMIS.plist
MobileSafety.dylib    TetherMeBT.dylib         libhide.dylib
MobileSafety.plist    TetherMeBT.plist         libhide.plist
-sh-4.0# ls /mnt1/var/
-sh-4.0#
sh-4.0# dd --help
Usage: dd [OPERAND]...
  or:  dd OPTION
Copy a file, converting and formatting according to the operands.
  bs=BYTES        read and write up to BYTES bytes at a time
  cbs=BYTES       convert BYTES bytes at a time
  conv=CONVS      convert the file as per the comma separated symbol list
  count=BLOCKS    copy only BLOCKS input blocks
  ibs=BYTES       read up to BYTES bytes at a time (default: 512)
  if=FILE         read from FILE instead of stdin
  iflag=FLAGS     read as per the comma separated symbol list
  obs=BYTES       write BYTES bytes at a time (default: 512)
  of=FILE         write to FILE instead of stdout
  oflag=FLAGS     write as per the comma separated symbol list
  seek=BLOCKS     skip BLOCKS obs-sized blocks at start of output
  skip=BLOCKS     skip BLOCKS ibs-sized blocks at start of input
  status=noxfer   suppress transfer statistics
BLOCKS and BYTES may be followed by the following multiplicative suffixes:
c =1, w =2, b =512, kB =1000, K =1024, MB =1000*1000, M =1024*1024, xM =M
GB =1000*1000*1000, G =1024*1024*1024, and so on for T, P, E, Z, Y.
Each CONV symbol may be:
  ascii     from EBCDIC to ASCII
  ebcdic    from ASCII to EBCDIC
  ibm       from ASCII to alternate EBCDIC
  block     pad newline-terminated records with spaces to cbs-size
  unblock   replace trailing spaces in cbs-size records with newline
  lcase     change upper case to lower case
  ucase     change lower case to upper case
  swab      swap every pair of input bytes
  sync      pad every input block with NULs to ibs-size; when used
            with block or unblock, pad with spaces rather than NULs
  excl      fail if the output file already exists
  nocreat   do not create the output file
  notrunc   do not truncate the output file
  noerror   continue after read errors
  fdatasync  physically write output file data before finishing
  fsync     likewise, but also write metadata
Each FLAG symbol may be:
  append    append mode (makes sense only for output; conv=notrunc suggested)
  directory  fail unless a directory
  sync      likewise, but also for metadata
  fullblock  accumulate full blocks of input (iflag only)
  nonblock  use non-blocking I/O
  noctty    do not assign controlling terminal from file
  nofollow  do not follow symlinks
Sending a INFO signal to a running `dd' process makes it
print I/O statistics to standard error and then resume copying.
  $ dd if=/dev/zero of=/dev/null& pid=$!
  $ kill -INFO $pid; sleep 1; kill $pid
  18335302+0 records in
  18335302+0 records out
  9387674624 bytes (9.4 GB) copied, 34.6279 seconds, 271 MB/s
Options are:
      --help     display this help and exit
      --version  output version information and exit
Report dd bugs to bug-coreutils@gnu.org
GNU coreutils home page: <http://www.gnu.org/software/coreutils/>
General help using GNU software: <http://www.gnu.org/gethelp/>
Report dd translation bugs to <http://translationproject.org/team/>
For complete documentation, run: info coreutils 'dd invocation'
-sh-4.0#
PostPosted: May 31st, 2018, 14:33
Forgot to mention. This is what I have been following.
http://msftguy.blogspot.com/2012/01/aut ... mentPage=2
PostPosted: June 1st, 2018, 16:09
The following command should display the contents of mount.sh:
    cat /bin/mount.sh
This command should list all the devices:
    ls /dev
Would it be possible to add a storage device (eg SD card) to the iPhone and then dd the raw, broken (?) partition to the card?
PostPosted: June 2nd, 2018, 19:11
The latest terminal output is below. Hope that helps. These old phones do not take SD Cards unfortunately, but it is connected to a Mac to get terminal access so might be possible to use that?
-sh-4.0# cat /bin/mount.sh
#!/bin/sh
# Script to mount the volumes..
MOUNTS=$(mount)
while read LINE
do
    set $LINE
    if [ $3 == "/mnt1" ]
    then
        MNT1=$1
    else
        if [ $3 == "/mnt2" ]
        then
            MNT2=$1
        fi
    fi
done <<< "$MOUNTS"
if [ -z $MNT1 ]
then
    if [ -b /dev/disk0s1s1 ]
    then # iOS5
        echo "Mounting /dev/disk0s1s1 on /mnt1 .."
        mount_hfs /dev/disk0s1s1 /mnt1
    else
        if [ -b /dev/disk0s1 ]
        then
            echo "Checking /dev/disk0s1 .."
            fsck_hfs /dev/disk0s1
            echo "Mounting /dev/disk0s1 on /mnt1 .."
            mount_hfs /dev/disk0s1 /mnt1
        else
            echo "Could not mount system volume; retry later or file a bug."
        fi
    fi
else
    echo "$MNT1 already mounted on /mnt1"
fi
if [ -z $MNT2 ]
then
    if [ -b /dev/disk0s1s2 ]
    then # iOS5
        echo "Mounting /dev/disk0s1s2 on /mnt2 .."
        mount_hfs /dev/disk0s1s2 /mnt2
    else
        if [ -b /dev/disk0s2s1 ]
        then # iOS 4
            echo "Mounting /dev/disk0s2s1 on /mnt2 .."
            mount_hfs /dev/disk0s2s1 /mnt2
        else
            if [ -b /dev/disk0s2 ]
            then # iOS3 .. maybe?
                echo "Checking /dev/disk0s2 .."
                fsck_hfs /dev/disk0s2
                echo "Mounting /dev/disk0s2 on /mnt2 .."
                mount_hfs /dev/disk0s2 /mnt2
            else
                echo "Could not mount user data volume; retry later or file a bug."
            fi
        fi
    fi
else
    echo "$MNT2 already mounted on /mnt2"
-sh-4.0# ls /dev
aes_0        klog          random          ttyp8
bpf0        md0          rdisk0          ttyp9
bpf1        mux.spi-baseband  rdisk0s1          ttypa
bpf2        null          rdisk0s1s1          ttypb
bpf3        pf          rdisk0s1s2          ttypc
btreset        ptmx          rmd0          ttypd
btwake        ptyp0          tty             ttype
console        ptyp1          tty.bluetooth      ttypf
cu.bluetooth     ptyp2          tty.debug          ttys000
cu.debug     ptyp3          tty.gas-gauge      ttys001
cu.gas-gauge     ptyp4          tty.gps          uart.bluetooth
cu.gps        ptyp5          tty.highland-park  uart.debug
cu.highland-park  ptyp6          tty.iap          uart.gas-gauge
cu.iap        ptyp7          tty.umts          uart.gps
cu.umts        ptyp8          ttyp0          uart.highland-park
disk0        ptyp9          ttyp1          uart.iap
disk0s1        ptypa          ttyp2          uart.umts
disk0s1s1     ptypb          ttyp3          urandom
disk0s1s2     ptypc          ttyp4          vn0
fsevents     ptypd          ttyp5          vn1
io8log        ptype          ttyp6          zero
io8logmt     ptypf          ttyp7
-sh-4.0#
PostPosted: June 2nd, 2018, 23:28
ISTM that, in the absence of arguments, the mount.sh script executes the following commands:
Obviously the second mount operation fails, probably because of a damaged HFS partition. It would be tempting to run fsck against the second partition but it's probably not a good idea (fsck is the Unix equivalent of CHKDSK).
I don't know which commands are available to you, but I would try to view the first sector of the damaged partition in hex mode.
    echo "ABCD" | hexdump -C
    dd if=/dev/disk0s1s2 bs=512 count=1 | hexdump -C
    dd if=/dev/disk0s1s2 bs=512 count=1 | file
The echo command tests whether the hexdump command exists and whether it is able to display hex data.
The first dd command reads the first sector of the partition and pipes it to hexdump.
The next dd command reads the first sector of the partition and analyses it.
Edit: You could use fsck_hfs with the -n switch ("Never attempt to repair any damage that is found"). I would confirm that the next line has the correct syntax before running it.
    fsck_hfs /dev/disk0s1s2 -n
https://man.cx/fsck_hfs(8)
PostPosted: June 2nd, 2018, 23:46
Maybe this would be better:
    fsck_hfs -n /dev/disk0s1s2
PostPosted: June 4th, 2018, 19:55
You can chain cat, dd and the ssh commands ( or netcat, if the platforms involved support it ) to transfer the dump of the partition to a computer.
PostPosted: June 4th, 2018, 20:02
This was my private suggestion to the OP:
What is the size of the damaged partition? What is the size of the RAM disk (rdisk)?
Would it be feasible to dd your data to the RAM disk as an image file, and then use SFTP to transfer this image file to your Windows PC? You may need to dd the partition as multiple sections.
http://osxdaily.com/2011/08/04/ssh-to-iphone/
What do you think? I only have a very rudimentary understanding (?) of *nix.
PostPosted: May 20th, 2019, 2:48
Hello guys, I didn't want to start a new thread so i'm replying to this one.
I have an Essential Phone with UFS 2.1 chip which has died and I have some important data on it.
It's encrypted by default (Android 9). I still have the PIN used on the device to decrypt.
Theoretically is there a way to dump the RAW data from the chip and then decrypt it on PC?
I also read online of people that have managed to swap the ufs chip from one device to another and were able to boot the device even with encryption. What would be the best way to do this and any services that you know who can provide a solution?
PostPosted: May 20th, 2019, 3:45
I wasn't able to find an adapter, but here is a bridge chip that looks promising:
JMS901 USB 3.1 Gen 1 to UFS/UHS-1 Bridge:
http://www.jmicron.com/PDF/brief/jms901.pdf
The JMS901 is an innovative and cost-effective USB 3.1 Gen1 to UFS 2.1 and UHS-I bridge controller.
@dnkta, have you investigated the possibility of getting your phone repaired?
PostPosted: May 20th, 2019, 3:50
Thanks. I will check it out.
Yes, i'm thinking to try to repair it first, if it doesn't work I have to try different route.
PostPosted: May 20th, 2019, 4:20
I could help you locate the voltage test points, but I would need hi-res images of the PCB(s).
PostPosted: May 21st, 2019, 12:03
seriously i dont understand why manufacturers encrypt chips first place?and why cant manufacturers provide remove encryption somewhere inside phone menu to turn off if you dont want it..
like warning text if you turn off encryption off your data will be no longer protected and anybody can read it,do you want proceed yes or no.
why cant users have option turn off encryption if they dont want it..
PostPosted: May 21st, 2019, 18:17
They are trying to protect you from yourself.
PostPosted: January 13th, 2020, 2:39
Have this eMMC from Huawei MediaPad M5
H26M62002JPR 32GB eMMC5.1 1znm 128Gb 11.5x13x0.8 153ball FBGA
It is Android 9 and encrypted, but it is not the case.
eMMC is from a working device, and was taken off properly (100% no damage to it).
But it cannot be seen in any reader/any computer/any OS. Seems like broken but it is not, 100%.
Found the same working device→chip-off→the same situation.
Has Huawei blocked anyhow the chip thus preventing any chip-off tryouts?
Have anyone heard anything?
Users browsing this forum: No registered users and 150 guests
