Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Can’t connect my WD5000AAJS
PostPosted: May 24th, 2018, 4:28
Well, your drive has an ext4 partition, so somehow that was created by someone. Filesystems don't just convert from one to other like that.
Either labtech is right and you're looking at the wrong drive, or someone messed it up.
Mystery will be solved when you run R-Studio / UFS / whatever supports ext4 and you look at the files.
PostPosted: June 3rd, 2018, 4:45
I installed R-Studio, but no idea then what to do with it.
Fab
PostPosted: June 3rd, 2018, 5:06
I understand.
I installed the wrong software:
However, recovery of the demo is limited to files no larger than 256KB with is quite a huge limitation.
Fab
PostPosted: June 3rd, 2018, 18:22
DMDE will attempt to find "phantom" partitions. Perhaps it will find remnants of a Windows installation. Just show us DMDE's Partitions window. That will take less than a minute.
PostPosted: June 10th, 2018, 16:07
I ran DMDE on my HD:
And here is the outcome of the scan:
Hope it tells you something (not the case for me)
Fab
PostPosted: June 10th, 2018, 22:38
It tells there are linux partitions, and probably a linux system installed on that drive.
The demo of R-Studio , when analyzing the partitions as EXT4, did find some file/folder structure ? Maybe your friend gave you the wrong drive, or it has been used elsewhere in the meantime and he forgot about that.
Users browsing this forum: No registered users and 58 guests
