 Post subject: ST1000LM014 SSHD
PostPosted: June 4th, 2018, 17:15
Hello
The drive in topic not spin up at all. ATA registers shows busy but no power up.
No terminal output/access. Is there any way to clear NAND? (unfortunately, don't have donor PCB)
Thanks in advance.
 Post subject: Re: ST1000LM014 SSHD
PostPosted: June 5th, 2018, 2:58
Hi
Reinitialize a NAND chip you can use command /OI. But if you have in Terminal error like Flash Erase Failure then probably is a problem with Nand chip and you need donor PCB.
Marcin
PostPosted: June 5th, 2018, 7:00
Do you personally imagine how to initialize a SSHD Rosewood drive on a foreign PCB?
PostPosted: June 5th, 2018, 12:37
ST1000LM014 is a Kahuna family and you can reinitialize foreign PCB . Rosewood is a diferent family and it is not SSHD drives.
PostPosted: June 5th, 2018, 14:50
Agree. It's Kahuna not Rosewood.
There's no terminal output at all.
I will try to find a donor PCB.
Thank you
PostPosted: June 6th, 2018, 8:51
This is Kahuna, but Rosewood SSHD do exist.... I am sure they are a lot more fun :lol:
PostPosted: June 6th, 2018, 13:30
Never see one yet. And I hope not. :D
PostPosted: June 23rd, 2018, 1:08
Detailed instructions to initialize drive of foreign PCB are available on the web you can research and will surely find it.
If you still can't find it PM me.
Users browsing this forum: Google [Bot] and 254 guests
