 Post subject: WDC WD30EFRX-68AX9N0 Massive Slowdown
PostPosted: June 20th, 2018, 19:57
HDD has massive slowdown on reads an especially writes.
Writes are at 1MB/s.
Tried 3 computers, win7/10, free dos, same results.
Tried 3 different cables - same.
Tried different ports - same.
Reformatted, blanked, deleted - same.
Dont know what to do?
Any help would be appreciated.
 Post subject: Re: WDC WD30EFRX-68AX9N0 Massive Slowdown
PostPosted: June 20th, 2018, 20:44
I just bought this one from a re-seller, but he refuses to admit its defective :)
Perhaps something like surface retest, or blank firmware :)
Bad luck i guess :D
PostPosted: June 20th, 2018, 20:47
That's both in windows? Def enabled.
Cant find the drive with MHDD, HDAT2 find it, but cant find anything useful in its plethora...
PostPosted: June 20th, 2018, 20:48
Perhaps, nothing can be ruled out :)
PostPosted: June 20th, 2018, 20:51
Bricking is of no issues now. If the tools are to expensive it would not be worth it though...
PostPosted: June 20th, 2018, 20:54
I set it to IDE and AHCI cant seem to find it with MHDD. in IDE mode there are 2 more controllers, but no hard drives...
I have Victoria for DOS and Windows, will check and get back
PostPosted: June 20th, 2018, 20:56
3 computers, and 3 cables. All other drives are perfect.
PostPosted: June 20th, 2018, 20:59
I did but he just ignores calls and messages. Great seller.
PostPosted: June 20th, 2018, 21:11
Victoria says
Unk.size; L/A=ON; Wr=ON;
Which means they are both on.
Seek test is like 300ms
Read test 256kb/s :D
Trying WD Marver
PostPosted: June 20th, 2018, 21:28
WD Marvel is of no help, ARCO and SS are disabled in free version.
Found WDR 6.0 but it just pops priviledged instructions.
Searching for 5.3
PostPosted: June 20th, 2018, 22:06
The answer might be in the average response time in the one image, which is 4350ms. A high response time without errors is usually an indication of the "slow" issue. The drive will read some data, then hang while the background scan is doing something, then read again, hang again... And as stated, who knows what the seller did to the drive. It can never be trusted with critical data for sure. But there is a way to disable the background scanning (aka the "WD slow fix"). Do a search on here for "slow fix" and look through the results... if Spildit doesn't post a more direct link before then :)
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: June 20th, 2018, 22:14
Spildit wrote:
Backup all modules and ROM with WDMarvel.
Please post :
ROM
Module 103
Module 40
Module 41
Module 02
Hopefully this is it :)
wdred.zip [278.97 KiB]
Downloaded 542 times
PostPosted: June 20th, 2018, 22:18
Spildit wrote:
Also a full zero fill would write to all sectors moving the ones on re-lo to G-List and the drive have 0 re-located sectors as well ... So the problem is elsewhere ...
Either ROM is not native or pre-amp is not working as it should, etc ....
Maybe the PCB itself have problems ?
Who knows ...
I tried cleaning and contact cleaner, alcohol all over it and reassembly. Same results.
Definitely something not that benign...
PostPosted: June 20th, 2018, 22:19
Oh i can post now :)
here are rom and modules.
Downloaded 576 times
PostPosted: June 20th, 2018, 22:23
Spildit wrote:
Uhhhmmm....
The drive does have 0 Pending sectors and the Slow issue is caused mainly by entries on RE-LO list that are processed by the MCU of the drive consuming a huge amout of resources ....
Doesn't look like the slow problem to me .... At least the one related to RE-LO list and bad sectors ....
Remember, we have seen a drive that had no pending or reallocated sectors suffer from the slow issue. If that is the problem then it still indicates that there is something wrong with the drive and it can't be trusted, but that would be up to the OP as to how the drive is used, knowing that it has issues and could fail at any time.
PostPosted: June 20th, 2018, 23:19
Hm the serial on the sticker and from dosdlg are he same. Does that mean no bad rom from another drive?
PostPosted: June 21st, 2018, 17:26
Thanks for everything, tracking down someone close here that have marvel full version, just to try ARCO and Self Scan.
Will report back :D
PostPosted: June 23rd, 2018, 21:30
Ok, got something done :)
Found a WDR 6.0 Free version and combined an old PC for Win 7 32bit with IDE compatible mode.
Did bunch of thing on the hard drive (clear smart, p-list, g-list etc) no change.
Did manual "slow fix" and HDD came to life.
Read and Write speed not quite perfect, but seek time is, anyhow much better. Here are some screenshots.
File comment: See the strange ripple on file copy to the drive...
File comment: Bad non sequential transfers...
PostPosted: June 23rd, 2018, 21:35
But, now I have another question :D
I have been playing with WDR and "fixing" old drives.
There is a problematic 2TB green drive, everything works fine, but when i did smart reset it would not erase #197 - Current Pending Sector Count.
I did surface test, Self Test, it just stays.
I tried manually changing module 21, even modified a .bas script so it shows me where are those SMART values in block 21 and 24.
While I can change block 24 - I cant 21. I write zeroes, a choose module write (same as i did for slow fix, and module 24) but it wont "take" :)
Any help with this?
Thank You all for opening this part of tech to me! :D
PostPosted: June 23rd, 2018, 21:54
Dully noted! :)
Users browsing this forum: No registered users and 66 guests
