 Post subject: Disable 411 and 02 module
PostPosted: June 27th, 2018, 22:18
For Western Digital hard drives, it often appears the situation that disk can not be ready due to long time busy status, or the disk can be ready, but when there is a data interaction, the disk turns into busy status and can not be ready again. In such a case, what we need most is the ability to read and write hard disk’s system area, only then can we modify firmwares of system area and solve the problem of long time busy status or slow responding.
The conventional method is to close the entry of system area or add defects to system area, and then load LDR to obtain the normal reading and writing access; What’s more, we can also use “Disable 02 module” function to obtain the reading and writing access of system area. However, these methods have their own limitations. For example, sometimes it is difficult to find needed LDR; On many new models, “Disable 02 module” function can not effectively obtain the reading and writing access of system area. And this is the time we need to use our new function of “Disable 411 module”, using this method to repair new Western Digital hard drives’ firmware problems can be much more effective.
“Disable 411 module” is applicable for hard drives with module 411, and this type of hard drives are relatively new. Using “Disable 411 module” on them is more effective than the other two methods. Below are specific steps:
1. If hard drive keeps busy status, we need to short circuit it or use jumpers, then power on the hard drive.
2. When the disk is ready, enter into MRT WD utility and click “Disable 411 module”, there will be log in log interface.
3. After that, we power off and on; if jumpers were previously attached, please remove them before powering on.
4. Please wait for the disk to be ready again, then re-enter into MRT WD utility.
Options of “Disable 411 module” and “Enable 411 modules” are listed as below:
And this is the link of demo video:
http://open.iqiyi.com/developer/player_ ... height=100%&width=100%
MRT Sales Consultant--Pink
Email: sales@mrtlab.com
Skype: live:sales_54921
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
 Post subject: Re: Disable 411 and 02 module
PostPosted: June 28th, 2018, 0:32
Iranian telecom blocked your link and bad news is that website can not access with proxy servers!!!
What am I doing here!?
Phoenix Computer Forensic Laboratory
http://www.databack.ir
PostPosted: June 28th, 2018, 2:26
Hi, sorry for the inconvenience, we have update the viedoto Youtube, the Youtube link is https://youtu.be/7EsrLwLvXVQ
Users browsing this forum: Google [Bot] and 73 guests
