 Post subject: What to do after paletter exchange?
PostPosted: July 4th, 2018, 15:07
Hi
I have 2.5 hp sas drive with damaged motor. I transfer the the only platters to identical drive. It spin fine but cannot be deleted at all. I swaped the pcb still not deleted.
Then I put back everything as it was amd the donor works fine.
Should I also transfer the heads?
 Post subject: Re: What to do after paletter exchange?
PostPosted: July 4th, 2018, 19:08
Deleted ? Do you mean you want to erase the data in it ?
If you do not want the data from it, better to just discard and buy another. A drive "rebuilt" like this couldn“t be trusted to normal operation.
PostPosted: July 4th, 2018, 19:25
I think he meant detected. Otherwise, how do you delete a PCB?
PostPosted: July 4th, 2018, 19:42
Yeah, makes sense.
PostPosted: July 5th, 2018, 13:31
I mean Detected :) phone auto correct.
Users browsing this forum: No registered users and 277 guests
