 Post subject: ST500DM002 Problem
PostPosted: July 14th, 2018, 5:20
Hi there !
I have st500dm002 firmware KC45, which is not detecting in bios but spinning normally no unusual sounds. after read channels shorting i got to F3T> here is the log plz assist me what should i do ? i ,ve backup of sys file 93h 1B 35h 28h and 346.
RECOV Servo Op=0100 Resp=0005[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
Trans.
Rst 0x10M
Spin Up
(P) SATA Reset
Trans.
F3 T>V40
Nonresident GList 0 entries returned
Total entries available: 0
PBA Len Flags Phy Cyl Hd PhySctr SFI
Rst 0x10M
Spin Up
(P) SATA Reset
ASCII Diag mode
F3 T>z
Input_Command_Error
F3 T>
F3 T>V40
F3 T>V4
Reassigned Sectors List
Entries: 0000, Alts: 0000, Removed: 0000, Pending: 0000
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs S
tatus BBM Mask
F3 T>/7
F3 7>X
Head 00 Resistance 00CA
Head 01 Resistance 00ED
 Post subject: Re: ST500DM002 Problem
PostPosted: July 14th, 2018, 5:53
Fucked heads to keep it simple.
PostPosted: July 14th, 2018, 9:48
If you don“t need the data, trash the drive and buy another from another brand.
If you or the owner needs the data, send it to a professional recovery . There are good people near you, and depending on the situation of the drive, it still may not be a costly recovery. If you keep messing and do something wrong, it may turn into one, though.
PostPosted: July 15th, 2018, 2:33
Thanks guyz,
