 Post subject: Crucial CT525MX300SSD1 - sectors read problem
PostPosted: July 14th, 2018, 8:15
Hello friends,
Just got this Crucial MX300 based on Marwell 88SS1074. It ID's good. Full Capacity, SN and model. But i can read only two sectors at a time. Then the drive won't read anything. It needs to be powered off and on, wait 5 seconds and then i can read another two sectors. Checked it on many sectors and this seems to be the only way to read the data. Did anyone have a similar case or has any idea how this can be solved in more automatic way?
odzyskiwanie danych
 Post subject: Re: Crucial CT525MX300SSD1 - sectors read problem
PostPosted: July 14th, 2018, 15:38
What hardware imager do you have? DeepSpar would work.
PostPosted: July 14th, 2018, 16:02
PC3000 only. I can't figure out why it needs those extra 5 seconds. It works like this: power on -> it gets DRD right away but it can't read any sectors. Have to wait 5 seconds. And can read only 2 sectors. It would be already done without it. With that speed of 2 sectors read, reset, wait 5 seconds and read next, 400MB of MFT will take 250h...
odzyskiwanie danych
PostPosted: July 14th, 2018, 19:25
at least twice as much
PostPosted: July 15th, 2018, 2:19
i click fast ;) But still... it's not an option.
odzyskiwanie danych
PostPosted: July 15th, 2018, 3:55
you can click as fast as you can
but still will be left with at least double that time
(you cant beat the calculator ;) )
400MB = 781,250 sectors / 2 (each read) (= 390,625(times to read them all)) * 5 (sec between each read) = 1,953,125 (seconds to read them all) = 542.5347H
assuming its 400MiB = 819200 sectors / 2 (each read) (= 409,600(times to read)) * 5 (sec between each read) = 2,048,000 (seconds to read them all) = 568.888H
PostPosted: July 15th, 2018, 4:12
Well, i beat your calculator yesterday. I did get the file list from the desktop in less than 10h.
Anyway, let's leave the math. I got 2 days to get the data and still no idea what the hell is wrong with this drive. Like it gets overflowed(i guess it's not a right word).
odzyskiwanie danych
PostPosted: July 15th, 2018, 5:21
try in reverse
PostPosted: July 15th, 2018, 6:11
I did. There's nothing that changes the way it works. Reverse, numer of sectors, ice, hot, i think i did all. Solution, if possible, must be in firmware i think. But those controlers are not supported by PC3k SSD yet. Waiting for monday to ask AceLab if they have any solution ready.
odzyskiwanie danych
