 Post subject: Preparing To Copy From C to A
PostPosted: July 18th, 2018, 14:05
I transfer by copying all the data from the drive a to b.
Then I formatted the drive a.
Now I'm trying to copy all the data from c to a.
When I drag and drop the files it says;
"Discovered ... Items"
"Preparing to Copy From C to A"
by calculating something.
But the screen closes and nothing happens.
How to fix that?
Note : I tried to copy files from the drive c to desktop. The drive C is alright.
But after format the drive A doesn't work as you can see.
 Post subject: Re: Preparing To Copy From C to A
PostPosted: July 18th, 2018, 18:03
Have you tried to copy the same files ( exactly ) from the "drive c" to the desktop ?
Also, what is the size of the drives involved ?
PostPosted: July 18th, 2018, 20:25
That's one of the reasons I never trust drag-and-drop to copy data. Sometimes it just creates shortcuts to the original files, and if you delete the originals, you are left with just shortcuts that point to files that no longer exist -- not copies of the original data. Not saying that's the case here, but something to check.
PostPosted: July 18th, 2018, 20:40
Yes, also size of the selected bunch, and if the disk has some problem.
Also, he doesn´t say if he can copy just one file to the new disk.
PostPosted: July 19th, 2018, 13:45
I found the reason. The problem is the drive has bad sectors.
I made Seatools test and It got "Fail"
I tried to copy the folders one by one. Although 2 folders I could transfer all of the files.
Users browsing this forum: Bing [Bot] and 37 guests
