 Post subject: About Bricked Kingston 120 Gb ssdnow 200 V+
PostPosted: July 21st, 2018, 13:17
Banned User
Can not seen in the bios. Can u help me to repair it? Where can i start for measurig components or any other pc programs? Mr. @fzabkar please help me!
 Post subject: Re: About Bricked Kingston 120 Gb ssdnow 200 V+
PostPosted: July 21st, 2018, 15:51
viewtopic.php?f=10&t=36313
viewtopic.php?f=10&t=35783
viewtopic.php?f=10&p=241918
PostPosted: July 31st, 2018, 10:14
Banned User
My PCB is similar to that: viewtopic.php?f=10&p=241918 (similar but nat same)
I use the 200 ohms range of multimeter and somewhere 200k range... Measuring results:
coil A : 109 ohm
coil B : 72.7 k
between 5vin-5vout : 49.2k
ground-5vin : 10.6k
ground-5vout : 39.2k
File comment: coil B
File comment: coil A
PostPosted: July 31st, 2018, 18:25
Those measurements appear to be OK. Can you now measure the voltages?
PostPosted: August 1st, 2018, 1:16
Banned User
voltage measure:
5V in and 5Vout = 5.1V (look like 5v e-fuse is ok)
coil A =1v and other side of coil A 0.44v
coil B = 2.87v and other side of coil B 1.5v
resistance up side 1R5 =2.85v (two sides 2.85v)
resistance down side 1R5= ( one side 1v other side 0.8v)
CAPASITOR GROUP ONE SIDE 5V OTHER SIDE ZERO VOLT (YOU CAN SEE PICTURE)
File comment: VOLTAGES
Optimal casual Dating
PostPosted: August 1st, 2018, 16:57
It appears that the voltages are OK. Just be sure, here are the actual test points:
MP2109DQ, Monolithic Power, Dual 1.2MHz, 800mA, Synchronous Step-Down Converter, 2.5V - 6V in, marking B7xx:
https://www.monolithicpower.com/pub/med ... 9_r1.4.pdf
MP28258DD, Monolithic Power, 3A, 4.2V - 20V Input, Synchronous Step-down Converter, marking AAA, QFN12:
https://www.monolithicpower.com/pub/med ... _r1.14.pdf
PostPosted: August 3rd, 2018, 10:32
Banned User
V1= 1v
V2= 1v
V3= 2.85v
V4= 2.85v
PostPosted: August 3rd, 2018, 16:53
ISTM that the problem could be firmware related. :-(
PostPosted: August 3rd, 2018, 23:53
Banned User
have you an idea to solve firmware problem?
what is the mean of ISTM?
PostPosted: August 3rd, 2018, 23:57
Sorry, I have no solution for firmware problems in SSDs. :-(
    ISTM -> it seems to me
PostPosted: August 4th, 2018, 3:24
Banned User
If i have same ssd, can i copy the firmware and flash the bricked ssd? Do you know a way to flash firmware for bricked ssd?
PostPosted: August 4th, 2018, 3:51
The "firmware" consists of several modules. AIUI, a common failure mode is corruption of the Flash Translation Layer. That's not something that a firmware download can repair. You could try waiting for an hour or so to see if the drive fixes itself and then comes ready, but I don't hold out much hope for you. :-(
PostPosted: August 4th, 2018, 19:42
FWIW ...
http://forum.acelaboratory.com/viewtopic.php?t=8973
Users browsing this forum: No registered users and 17 guests
