Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: power problem ADATA SU900
PostPosted: August 5th, 2018, 18:29
One thing you might like to try is to disable U6 by shorting its enable pin to ground.
Enable
When input voltage is greater than the undervoltage lockout threshold (UVLO), typically 2.3V, MP2162 can be enabled by pulling EN pin to higher than 1.2V. Leaving EN pin float or pull down to ground will disable MP2162.
Then see if the other voltages are stable.
PostPosted: August 6th, 2018, 11:20
After disabled MP2162 current is still not stable and still changing in every points. I marked capacitors connected to 1.5V point.
PostPosted: August 6th, 2018, 17:24
When you grounded the enable pin of U6, did its output remain at 0V? If not, then it must be faulty.
Otherwise I'm out of ideas.
PostPosted: August 7th, 2018, 2:30
No, after grounded enable pin still showing changing current between 0,1 to about 2,2V but not 0V.
PostPosted: August 7th, 2018, 2:47
Either U6 is faulty, or there is an open feedback resistor. See R1 and R2 in the application circuit.
PostPosted: August 7th, 2018, 3:09
sorry where is resistor R1 and R2 ?
PostPosted: August 7th, 2018, 3:28
See attachment.
PostPosted: August 9th, 2018, 10:23
Thank you fzabkar for your help. Unfortunately I don't resolved this case.
PostPosted: August 10th, 2018, 14:14
This case probably can be solved, so hope you redirect client to another lab.
Users browsing this forum: No registered users and 92 guests
