 Post subject: st9500325as SATA interface limited to 1.5Gbps?
PostPosted: September 2nd, 2018, 14:24
Hello :)
This HDD was extracted from Seagate Freeagent Goflex 500gb external enclosure bougth in 2010. Reason was, this case only supports USB 2.0. I wanted to put it in faster usb 3.0 box.
Then I run CrystalDiskInfo to check for badblocks etc. and everything seemed fine (attachment).
But one thing bothered me - Transfer mode SATA/150(attachment)
This drive should support 3.0Gbps speeds. I checked on other computer and the same thing (and on other usb3.0 enclosure - the same)
Then I remembered that old SATA Seagate drives could be jumper limited to 1.5Gbps. But there is no jumper on pins near sata connector. I tried putting jumper in all possible combinations (3) - no change.
So I connected this drive to UART adapter to work with putty terminal to get some info about it.
Here is Ctr+A log:
F3 T>
Package Version: WY05D7.BSM1.DA99L4.0002BSM1, Package P/N: ---------, Package Builder ID: 84,
Package Build Date: 07/29/2009, Package Build Time: 16:19:59, Package CFW Version: WY05.BSM1.00190457.8400,
Package SFW1 Version: 7DBC, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 00990001, CustomerRel: 0002, Changelist: 00190457, ProdType:WY05.BSM1, Date: 07/29/2009, Time: 161959, UserId: 00080603
Servo FW Rev: 7DED
RAP FW Implementation Key: 0E, Format Rev: 3D03, Contents Rev: 26 1E 04 05
and Ctrl+I log:
F3 T>
TetonST Rev: 63A2; No Host; SpdLimit: 1.5Gb; SSC: No; LED: No; StagSpinByp: Yes ;
AT Registers
100A0000: 0001 0001 0000 0000 0000 C0FF 1080 0042
100A0010: 0000 0000 0000 1C00 0000 2B00 0000 0000
100A0020: 0100 0000 00EA 0410 0000 0001 0000 1B00
100A0030: 0000 0000 0004 0000 0000 0000 0000 0001
100A0040: 0000 00FB 0000 0000 0000 0400 0000 00FF
100A0050: 0000 0000 4795 57A5 CE2D 0000 0000 0000
100A0060: 0001 0000 0000 0000 0000 0000 0000 0000
100A0070: 0000 0000
CUT....then long text with other registers.
and I see this SpdLimit: 1.5Gb
I read F3 Seagate terminal commands documentation and could not find an option or command to change this setting.
Anybody knows if it is even possible or is it hardcoded in PCB or read only firmware?
Thanks for any information!
Regards,
yaccc
 Post subject: Re: st9500325as SATA interface limited to 1.5Gbps?
PostPosted: September 2nd, 2018, 17:12
Can you see a relevant parameter in your own Mode Pages?
http://forum.hddguru.com/viewtopic.php?f=1&t=34131
PostPosted: September 3rd, 2018, 4:03
Could not find such option or I don't know which parameter can alter this setting.
F Parameters dump in attachment.
Kind regards,
yaccc
F.txt [49.01 KiB]
Downloaded 1117 times
PostPosted: September 3rd, 2018, 4:46
I couldn't find any likely candidate, either. :-(
In any case, I don't believe your drive's maximum sustained data rate will approach the SATA link rate of 150MB/s, which means that there will be no speed benefit at 3Gbps.
PostPosted: September 3rd, 2018, 5:54
Yeah, I know this and I can live with this :) But interesting is if it is possible to change this parameter.
I could not find any documentation about SATA Registers displayed when Ctrl+i pressed.
Attached files show all the registers - affected (limited) drive (registers500gb5400.txt) and other seagate momentus without limitation (registers250gb7200.txt)
Maybe there is some switch that controls this setting. Are those registers editable? I compared that files and there are 7 differencies.
Thanks!
registers500gb5400.txt [3 KiB]
Downloaded 1374 times
registers250gb7200.txt [3 KiB]
Downloaded 1168 times
PostPosted: September 3rd, 2018, 16:06
I would think that these registers would be volatile and would be configured at power on. They would be associated with the SATA controller device within the MCU.
Are you able to see the SpdLimit information when the PCB is detached from the drive? If so, then this would prove that the setting is in the ROM.
PostPosted: September 3rd, 2018, 16:18
Your Mode Page dumps suggest that there are at least 4 configurable settings in ROM:
Byte:0570:       BootFlagsForROM = 02 00
Byte:0570:           Bit:0, BOOT_FLAG_POWER_ON_IN_STANDBY = 0
Byte:0570:           Bit:1, BOOT_FLAG_PARTIAL_OOB = 1
Byte:0570:           Bit:2, USE_SMALL_ID_FORMAT = 0
Byte:0570:           Bit:3, LOW_CURRENT_SPINUP = 0
If you are willing to experiment, you could read the ROM, change the LOW_CURRENT_SPINUP setting, and then dump the ROM again. By comparing the two dumps you could locate those bytes which store these settings.
    F"LOW_CURRENT_SPINUP",1,22
Read and Write F3 Arch Sys files with HyperTerminal :
http://www.hddoracle.com/viewtopic.php?f=83&t=145
You can read the ROM via terminal by reading sys file 32A.
    r32a,09,0
PostPosted: September 4th, 2018, 6:00
Yes, the SpdLimit parameter is still visble on detached PCB.
I tried to read ROM but unfortunately this HDD does not support r/w commands.
F3 T>r32a,09,0
Invalid Diag Cmd
I downloaded SeaChest tools and tried using SeaChest_Configure --phySpeed 2 or 0 setting but again - not supported by this hdd.
(--phySpeed [0 | 1 | 2 | 3] (SATA Only)
Use this option to change the SATA PHY speed to a new maximum
value. This change persists over power cycles and resets.
0 - allow full negotiation (default drive behavior)
1 - allow negotiation up to 1.5Gb/s
2 - allow negotiation up to 3.0Gb/s
3 - allow negotiation up to 6.0Gb/s)
Kind regards,
yaccc
PostPosted: September 4th, 2018, 15:53
Sorry, the correct URL should have been ...
http://www.hddoracle.com/viewtopic.php?f=83&t=1455
PostPosted: September 4th, 2018, 20:25
What does the drive report in words 76 - 79 of the Identify Device data block? You could use CrystalDiskInfo to retrieve this information.
In particular, word #76 reports whether the drive supports SATA Gen2 Signaling Speed (3.0Gb/s) and SATA Gen1 Signaling Speed (1.5Gb/s).
The corresponding bytes of the Congen Mode Page appear to be ...
Byte:0464: SATACapabilities = 0E 05
Byte:0465: Bit:0, SATA_NCQ_SUPPORTED = 1
Byte:0465: Bit:1, HOST_INITIATED_PHY_POWER_MANAGEMENT_SUPPORTED = 0
Byte:0465: Bit:2, SATA_PHY_EVENT_COUNTERS_SUPPORTED = 1
Byte:0465: Bit:3, UNLOAD_WHILE_NCQ_CMDS_OUTSTANDING_SUPPORTED = 0
Byte:0465: Bit:4, NCQ_PRIORITY_SUPPORTED = 0
Although the SATA speed settings are not explicitly listed, a value of 0Eh in byte 0464 corresponds to the settings for Gen1, Gen2 and Gen3. That is, all are enabled.
PostPosted: September 6th, 2018, 18:52
Identify Data for this HDD words 70-79
070: 0000 0000 0000 0000 0000 001F 0502 0000 0048 0040 .................H.@
076 is 0502, from my calculations for SATA 3.0Gbps should be 0504 - correct? Possible to change it?
PostPosted: September 6th, 2018, 20:23
I would enable both speeds, ie 0x0506.
That said, I would have expected Identify Device word 76 to reflect the content of bytes 0x0464 and 0x0465 of the Congen Mode Page, ie 0x050E. I confess I don't understand this apparent anomaly, or how to proceed. :?
You might try changing the "SATACapabilities" word, but that's your choice. You might also like to examine the DCO (Drive Configuration Overlay). HDAT2 should be able to do this, if the drive supports it.
BTW, were you able to read the ROM? If yes, then try reading sys file 93. That's where the Congen parameters would be stored.
Edit: I missed this:
This means that the speed limit setting is in the ROM, and that the ROM is overriding sys file 93.
PostPosted: September 6th, 2018, 20:46
I suspect that the IAP ROM module may be the location for the SpdLimit setting:
http://www.hddoracle.com/viewtopic.php?f=59&t=2173&p=14702#p14687
The IAP/CAP/SAP/RAP ROM parameters can be displayed and modified using the "I" command at level 2 or 7.
PostPosted: September 7th, 2018, 3:42
F3 T>r32a,09,0
Invalid Diag Cmd
I tried 'I' command on levels 2 and 7:
F3 T>/2
F3 2>I
(P1=00) Invalid:
F3 2>/7
F3 7>I
(P1=00) Invalid:
F3 7>/
I will check HDAT2.
PostPosted: September 7th, 2018, 4:44
F3 T>r32a,09,0
Invalid Diag Cmd
Did you follow Spildit's HDD Oracle tutorial?
F3 T>/2
F3 2>I
(P1=00) Invalid:
F3 2>/7
F3 7>I
(P1=00) Invalid:
F3 7>/
The "I" command requires parameters, eg ...
    I,0
    I,1
    I,2
    I,3
    I,4
    I,FF
PostPosted: September 7th, 2018, 9:52
Yes, I did. He notes there, that r/w commands do not work on every drive.
ASCII Diag mode
F3 T>
e c r = 0 0 1
e c r = 0 1 0
e c r = 0 1 1
e c r = 1 0 0
e c r = 1 0 1
e c r = 1 1 0
F3 T>r133
RW cmd 0002 req = 5D 7E 00 00 80 01 00 00 00 00 00 00 00 C0 03 00 FF 7F 04 00 00 C0 03 00
opts = 00001121
Invalid Diag Cmd
F3 T>
I tried I,0 ..... I,5 and none of them lists IAP Parameters.
F3 2>I,FF
Adaptive Parameter Groups Table of Contents:
(P1=01) RAP (Read/Write):
(P1=02) SAP (Servo):
(P1=03) RW Working Parms:
(P1=FF) Table of Contents:
F3 2>
PostPosted: September 7th, 2018, 15:49
Here is the header from an ST9500325AS ROM:
Offset(h) 00       04       08       0C
00000000  771F0000 38000000 40980000 A2690400
00000010  02300000 0430F805 0640FA05 0360A406
00000020  0B60C407 0560D507 0078F507 00000000
There is no IAP module (ID = 0Eh), only CAP, RAP and SAP.
You could see a complete list of supported commands by typing Q at Level C.
PostPosted: September 9th, 2018, 12:33
So... no chance to change this?
All supported commands in attachment q.txt
q.txt [20.84 KiB]
Downloaded 1324 times
PostPosted: September 9th, 2018, 16:19
I'm sure there is a way, but I don't have the answer.
PostPosted: September 10th, 2018, 1:21
OK! Thanks for your efforts.
Kind regards,
yaccc
Users browsing this forum: No registered users and 66 guests
