 Post subject: Wanted: WD USB SED Locked Drive
PostPosted: September 9th, 2018, 17:02
I am looking to acquire a WD USB SED locked drive that does not have access to ROM or RAM. It can have bad sectors, and can be suffering from the “slow” issue. And actually if it does have bad sectors and is suffering from the slow issue, that is a bonus to me. I do not want one with a bad head. I also don’t really want one that has been “refurbished” where I don’t know what has been done to it to “refurbish” it. The purpose of the drive is for experimentation. If anyone can help, please either reply or PM me with details.
http://www.hddsuperclone.com
Home of HDDSuperClone
 Post subject: Re: Wanted: WD USB SED Locked Drive
PostPosted: September 10th, 2018, 4:31
Posted on Ace Forum :
http://acelaboratory.ru/forum/viewtopic.php?f=37&t=8508
The unique method firstly and solely developed by ACE Lab makes one more breakthrough in recovering data from the encrypted WD!
Now you can recover data from Self-Encrypting Drives which are encrypted not by the USB bridge but via the Main Drive Processor.
Our newest proprietary method implemented in WD Marvell utility empowers you to forget about any donors when recovering data from all kinds of encrypted WD drives.
Earlier, when dealing with the damaged Self-Encrypting Drives (SED), it was necessary to transfer the encrypted image from a damaged drive to a donor drive before starting the data recovery process. It took a lot of time to transfer the data, to find an appropriate donor and to buy it.
Starting from now, the PC-3000 users get the opportunity to use a unique time-saving method to recover data from WD Self-Encrypting Drives (SED) encrypted by the Main Drive Processors, such as 88i9045, 88i9146, 88i9346, 88i9446, 88i1047, etc.
The main feature of such hard drives is that they not only have the User Area encrypted, but also have the Service Area access blocked. Usually, when the access to the Service Area is unblocked, the User Area data cannot be decrypted at once, and it is impossible to work with the Service Data and User Data simultaneously.
The extended functionality of the PC-3000 utility for encrypted WD Marvel HDDs enables to overcome this restriction due to the unique software decryption of the User Area "on the fly". This approach makes it possible to work with such drives in the Data Extractor directly without transferring the encrypted image to another drive.
Moreover, the data can be decrypted even if the user forgot the password!
This technology created by ACE Lab is not available anywhere else.
Being at the front edge of data recovery technologies, ACE Lab is happy to share the innovations with you in the latest PC-3000 software version 5.9.21 which will be released soon.
<span style="color: #0080FF">Be part of the solution, not the problem.</span>
<span style="color: #0080FF"><a href="https://datarecoverysa.co.za" class="postlink">Data Recovery Cape Town</a></span>
PostPosted: September 11th, 2018, 10:53
^^^ That's an old post from AceLabs. The current software revision is more like 6.5.18.
They do not yet have a solution for these latest encrypted models, such as Palmer Passports.
If the OP is looking for a Palmer drive, a typical model number is WD10SDZW-11UMGS0.
The ROMs on these do not appear to be locked.
http://www.datasaversllc.com
PostPosted: September 11th, 2018, 17:48
I guess I should clarify. I am not looking for the newest model. I just want one of the common ones that has the ROM and RAM access locked so that the slow fix cannot be applied through USB using the likes of HDDSuperTool. My purpose is to be able to read ROM and access SA with only a computer and my software with hopes to be able to apply the slow fix, all without any fancy expensive hardware.
PostPosted: September 12th, 2018, 10:07
FYI, the drives you further describe offer access via the serial port.
The newer ones that don't interest you don't.
PostPosted: September 14th, 2018, 8:47
What is the definition of no solution? Does that mean that SA cannot be accessed even with a compatible SATA board? Or just that they can't decrypt them with a SATA board?
I have no intentions of attempting any decrypting, that is beyond me. But if a SATA board can currently be used to apply the slow fix, and then the USB board has to be put back to clone, I would hope to eliminate the need for a SATA board just for the slow fix, and be able to access SA through USB. It would be the same process as the models I was originally intending, IF it works. If SA can be accessed with a SATA board with the normal procedure (that starts by patching ROM so it doesn't load SA), then one of the newer drives should work for my experimentation.
PostPosted: September 14th, 2018, 8:59
For now Palmer family can't be read SA. Some kind of encryption that still doesn't allow access to modules.
ACELab partner
PostPosted: September 14th, 2018, 11:05
I can access those
PostPosted: September 14th, 2018, 15:28
Doomer wrote:
I can access those
Handy to know :-)
PostPosted: September 14th, 2018, 17:05
Doomer wrote:
I can access those
Just curious, do you gain access through USB, or after converting to SATA?
PostPosted: September 14th, 2018, 17:10
So what are some model numbers of the SED locked drives prior to these new ones? I am still looking to get one as long as the price is right.
PostPosted: September 14th, 2018, 17:52
Doomer wrote:
I can access those
Not willing to share, do you?? :mrgreen: :mrgreen:
ACELab partner
PostPosted: September 22nd, 2018, 12:41
I just purchased a used WD10JMVW-11AJGS1 that is supposed to be in good condition, as data that I have shows this is one of the SED locked drives I was asking for. When it arrives, I will be able to test if my method is possible or not.
And then I went crazy and purchased a WD10SDZW-11UMGS0 that is considered a parts drive, but is supposed to be functional with only 1 bad sector. I really doubt I will get anywhere with that drive, but the price wasn't bad, so I just had to buy it to try. Maybe I will surprise myself, or maybe it will just be a waste of time and money. No way to tell without trying.
PostPosted: September 24th, 2018, 13:34
With WD10JMVW SED drives the SA is locked. But the SA can always be unlocked by converting the board to SATA, putting the drive in kernal mode, changing the SA regions, using an overlay from a donor and then disabling the SA lock which will also disable the decryption. Then the slow fix can be applied or any other changes to the SA, then the SA lock and decryption can be put back to normal.
Is this not possible with WD10SDZW? is there no way to access the SA as of yet?
PostPosted: September 24th, 2018, 16:32
See viewtopic.php?t=37418
I don't know why it works, but the trick was applied to a WD10JMVW-11AJGS2 to circumvent a BSY problem. I expect that it won't work with WD10SDZW models, though.
PostPosted: September 24th, 2018, 17:40
My goal is to be able to perform this operation on drives such as the WD10JMVW with the USB board, not requiring SATA conversion. I won't know if I can do that until I have the drive and do some testing. I have some crazy (probably delusional) hope that I would be able to access the WD10SDZW like that also.
PostPosted: September 26th, 2018, 20:32
The WD10SDZW-11UMGS0 arrived, and I cannot get USB access when trying to put it in kernel mode. So no chance of me doing anything with that drive.
I will have the WD10JMVW-11AJGS1 soon, but I don't have high hopes. If I end up with the same results, my idea for USB access to these drives will be dead.
PostPosted: September 27th, 2018, 19:14
The WD10JMVW-11AJGS1 arrived, and my hopes and dreams have been killed. No USB access in kernel mode. I had hopes that it would work like the older passport drives I have, but to no avail. This attempt is now dead, case closed.
PostPosted: September 28th, 2018, 4:56
WDC WD10SDZW-11UMGS0
Raminfotech Data Recovery
Chennai's No.1 Data Recovery Center
http://www.raminfotechdatarecovery.com
skp:raminfotech.vijayan
PostPosted: December 23rd, 2018, 4:27
How does one do this? Which pins do you connect with?
