 Post subject: WD20EFRX - damaged -> No function - pcb bad
PostPosted: September 18th, 2018, 6:23
i have here a WD20EFRX - NO FUNCTION
I remove bad diodes D4 and D2 + R43 (now bridged).
PCB is only bsy. -> No spinn.
I can see near L6 D7 a chip with letters ASPAD the case has a little hole
(or may be a simple surface damaged) !?
What is the function of the chip ? (Power reg. ?)
what can I test next?
Thanks for any help (and have no donor pcb here).
 Post subject: Re: WD20EFRX - damaged -> No function - pcb bad
PostPosted: September 18th, 2018, 15:25
R43 is in series with D3 and D1, not D4 and D2. :?
A photo of the area would help a lot, but if you are referring to Q1, then that's a MOSFET. Q1, together with L6 and D7, constitutes a switchmode regulator with PWM control provided by the motor controller.
PostPosted: September 21st, 2018, 10:41
Hello fzabkar,
fact is D2 and D4 is damaged.
I get now a new pcb and all works.
PostPosted: September 21st, 2018, 15:22
Then I would have expected R60 to be open circuit, not R43.
Users browsing this forum: Google [Bot] and 52 guests
