 Post subject: WD5000LPVT-22G33T0 LDR file needed
PostPosted: September 25th, 2018, 4:47
need ldr for the same, anyone can help?
 Post subject: Re: WD5000LPVT-22G33T0 LDR file needed
PostPosted: September 25th, 2018, 20:00
over 2.5 years in the file section
http://files.hddguru.com/index.php?acti ... ty/Hubble&
PostPosted: September 26th, 2018, 1:46
ldr is not there
PostPosted: September 26th, 2018, 3:16
shubhsinghal wrote:
ldr is not there
11.rpm
PostPosted: September 26th, 2018, 8:48
with all due respect
outsource it to someone who knows what he is doing
PostPosted: September 26th, 2018, 10:53
Did you got all data recovery knowledge in one day ?
PostPosted: September 26th, 2018, 19:03
The link firmware version I think is 00002004Q.
Although I think it's fine, for the album you're looking for.
Someone with more experience than I could corroborate you.
In the most modern discs apart from the 0x11 module it is important to load the 0x411, if I am not mistaken.
Greetings.
PostPosted: September 27th, 2018, 1:31
Thanks, done with it.
support is always required.
PostPosted: September 27th, 2018, 18:40
No problem, there is always a learning curve. Best Wishes from Mumbai
