 Post subject: [Help] ST500LM000 - not recognized
PostPosted: September 28th, 2018, 6:01
Hi all,
I hope you can help me to solve the problem that I have with this hd.
ST500LM000 SSHD 500GB 8GB NAND 5400 rpm
SN: W766H RW3
PN: 1EJ162-076
FW: LVD5
board ver: 100731589 rev A
The motor spins up and it can be hear only one click of the head.
I tried to change logic board with donor board. I swapped bios ic but no success. With donor board the disk is completely dead no motor spin up, no click.
The two board (patient and donor) only differ for NAND chip as you can see by the image attached (on the right the patient board)
Any suggestion?
Thanks in advance.
 Post subject: Re: [Help] ST500LM000 - not recognized
PostPosted: September 28th, 2018, 7:20
Forse questo thread potrà aiutarti
viewtopic.php?f=1&t=35895&p=251230&hilit=sshd+nand#p251230
Tanto per cominciare, hai l'adattatore seriale per vedere cosa dice l'output a livello terminal al momento dell'accensione?
Perhaps this thread will help you
To begin, do you have the serial adapter to see what the terminal-level output says at power-up?
My firmware database:
PostPosted: September 28th, 2018, 18:51
Many thanks for interesting.
I do not have serial adapter. Could you suggest me anything suitable to buy?
PostPosted: September 29th, 2018, 2:49
Pls send ful details patient and donor drive , but if the drive spin up it is not the electronic board issue
Backup is Your best friend. Still learning English. Sorry for language bugs. My websites: Centrum Odzyskiwania Danych
PostPosted: September 30th, 2018, 5:22
probably it's not pcb problem
data recovery Poland
PostPosted: October 1st, 2018, 11:46
Hi all,
with an arduino uno like an RS232 adapter and Putty @38400 baud rate I receive this on startup:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
PostPosted: October 2nd, 2018, 16:47
Please, nobody can help me?
PostPosted: October 2nd, 2018, 16:59
You say “click of the head”....
Could you record and post the sound?
It’s 99.9% not a PCB issue.
PostPosted: October 3rd, 2018, 9:04
Attached, the sound.
hdmik.zip [47.83 KiB]
Downloaded 481 times
PostPosted: October 3rd, 2018, 16:35
Sounds awful to me, don’t power it up anymore.
Horrible scraping noise.
PostPosted: October 3rd, 2018, 16:41
In my opinion the heads are wrong and almost certainly damaged the surface.
The subject seems quite complicated and with partial data loss very very likely.
That disc as @pcimage says the more you turn it on the more it will be damaged, in principle, but until there is nothing there is sure.
PostPosted: October 4th, 2018, 3:27
I'm newbie so I can't evaluate the sound.
In my opinion I hear the motor spin up and the head that try to read something and go back to parking pos.
However, I'm trying to understand and I would know:
1) why when I put donor board with patient bios ic the motor doesn't spin up? The donor board is faulty?
2) The donor board with its bios show T> terminal. The patient not. Is it possible that the patient bios is corrupted?
PostPosted: October 4th, 2018, 13:24
This is a SSHD, not a “normal” drive.
Not a good drive to be working on if you’re a “newbie”, sorry to say :-(
PostPosted: October 4th, 2018, 13:53
Olso think it is the head defects and can be platters degradation. I think You need profesional help for this HDD.
