Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Introduction of MRT software version 2127
PostPosted: September 28th, 2018, 11:21
saltwater wrote:
Hi!
When MRT failed to load the drive SA module dir, and using default module dir, close utility, and open it again.
Sometimes the MRT utility does not get enough time for the drive to gain access to SA module list (FIT), and the utility jumps out this important step, and uses "default module list".
It makes sense but it's not the case yesterday I power on the drive and mrt immediately load the drive SA module dir, after a while I power on again but now even after four times I close utility and open it again mrt still failed to load the drive SA module dir only in the fifth time it did, but it's not a big deal the real problem of can't read rom and can't edit head map is remain although I hope it will be fix in the new update 2128 mrt upload few days after the current but it still does not work.
PostPosted: October 3rd, 2018, 13:29
Spildit wrote:
For some reason many tools like MRT and SeDiv do apear to have problem with this and are not able to properly work with majority of "modern" drives to read/write ROM by terminal. SHTR works fine with those ...
Can you edit head map in ram in common samsung 2.5" with SHTR ?
PostPosted: October 3rd, 2018, 17:39
Spildit wrote:
If the goal is to clone/image by heads you can use SHT/SHTR to read the zone table :
The goal is in case of scratches on platters it's better first disable head in ram then do head map in cloning tool and hot swap involved here also.
PostPosted: October 3rd, 2018, 17:40
It's good ideas but my goal is in case of scratches on platters it's better first disable head in ram then do head map in cloning tool and hot swap involved here also.
Users browsing this forum: No registered users and 6 guests
