 Post subject: WD10EZEX-08WN4A0 - Need help
PostPosted: September 24th, 2018, 10:45
HDD : WD10EZEX-08WN4A0 with F/W 5.5HH
Family : TrailXLB2(Royal)
Tool : Wdmarvel 3.3.1 Registered
The hdd makes clicks and after 2-3 min spindown. IF region map changed then loaded overlay then some modules can be read( There is always mild click sound).
I wrote the ROM from WD10EZEX-22MFCA0-01.01A01-05.5HH and changed to the patient SA Region then can read all the modules without error. but can not access the UA. After switching to this rom no click sounds.
Both ROMs SA regions are same but Dir Module address is different
ie. With Original ROM I can't read all modules but with Other ROM can read all modules without Problems.
Here attached both ROM images with ROM modules.
Modules-Patient.rar [204.02 KiB]
Downloaded 510 times
Modules-Donor.rar [203.99 KiB]
Downloaded 497 times
is there any problem in original ROM?
 Post subject: Re: WD10EZEX-08WN4A0 - Need help
PostPosted: September 24th, 2018, 12:57
Can you read the 2 copies of the SA without problems?
PostPosted: September 24th, 2018, 13:45
In addition to probably having problems with some head, you can not access the user area to be the drive SED
PostPosted: September 25th, 2018, 0:24
Sure can read both copies without problem.
Head test took long time without error in original ROM. In other ROM quickly passed that test in SA track.
Can I perform that head test in UA?
This drive is not SED Locked Drive.
Which ROM modules (Adaptive) to transfer from patient rom to donor rom?
PostPosted: September 25th, 2018, 8:41
Are you sure about this?
There are several types of SED.
Different addressing of mod 01..... :roll:
PostPosted: September 25th, 2018, 10:03
Which module to checked for this SED Lock is present or not?
I can send any modules from this drive.
Thankyou
PostPosted: September 25th, 2018, 14:55
I think that depending on the symptoms of the disc, one of the heads may be wrong.
If you can edit the ABA address, in the 0x0B module with WDMARVELL, you would try to leave the two ABA addresses of copy 0 and 1 pointing to the same copy.
Try copy 0 first and if it does not go well you can try to point to copy 1.
It's a suggestion.
PostPosted: October 3rd, 2018, 8:25
Now the drive is visible in windows but full of bad sectors.
using both heads H0 & H1 can read & Write in SA but in UA only H1 read. H0 can't read even single sector.
ie: H0 can read & write in SA but not read even single sector in UA.
I have only WDmarvel 3.3.1.
What i have to do ?
Note: WDmarvel 3.3.1 can't able to edit headmap in RAM. Checked this in brand new HDD of the same model.
PostPosted: October 3rd, 2018, 12:03
If this is a client job, you better outsource to someone with the needed tools and experience to rescue data.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 3rd, 2018, 12:45
Can someone indicate where the SED flag is located?
PostPosted: October 3rd, 2018, 15:33
Analysis of Western Digital ROYL firmware MOD 02 -- SED lock:
http://www.hddoracle.com/viewtopic.php?f=59&t=821&p=9224#p9077
Users browsing this forum: Google [Bot] and 223 guests
