 Post subject: BIOS WED5000BEVT-22A0RT0
PostPosted: October 5th, 2018, 5:47
have a WD5000BEVT. See Details
WED5000BEVT-22A0RT0
2060-771672-004 REV A
PN: XXXXX-XXX
Faileure: Wont recogniced by BIOS and System
I NEED THE FIRMWARE BIOS
 Post subject: Re: BIOS WED5000BEVT-22A0RT0
PostPosted: October 5th, 2018, 6:29
If you need the ROM, I can send it to you within 4 hours.
PostPosted: October 5th, 2018, 6:50
perfect, thank you very much
PostPosted: October 5th, 2018, 9:58
I pass the firmware
Firmware.zip [5.11 MiB]
Downloaded 495 times
PostPosted: October 9th, 2018, 6:27
the data that I have of the hdd are:
MDL: WD5000BEVT-22A0RT0
WWN: 50014EE600B137F5
DATE: 28 NOV 2010
DCM: HVNTJVB
DCX: 5A060B4R6
R / N: 771672
PRODUCT MALASYA
The original bio makes the platters do not turn, if I put another bios of a similar disc, if they turn me on and logically I do not recognize it, but if I turn the platters.
The original bio in another similar disc also makes the platters do not rotate.
The original bio does the same thing on several similar discs
PostPosted: October 11th, 2018, 7:06
yes, I have MRT
Spildit wrote:
Do you have MRT or any other firmware tool ? Can you READ original ROM ? If so please do post it.
Does your PCB have an external ROM chip ? It should have. Can you read it with external programmer ? If you manage to get a dump please post it.
Now with compatible ROM+Loader can you gain access to SA ? If so you might be able to get some modules needed to regenerate the adaptives on ROM that you will be missing by the use of non-native ROM.
Also if the PCB does have external ROM you will NOT have a copy of ROM modules on SA... Or in better words there will be just templates without usefull data to regen ROM and you will need to use other tricks.
PostPosted: October 12th, 2018, 4:59
If with the original BIOS the disk is not set when starting a moment in bsy, and with the other of the same model if, it is that the original ROM is wrong (with a high% chance).
When you place the hard disk donor you must have access to the SA and then rebuild the ROM.
Have you tried this?
Greetings.
Users browsing this forum: WebClaw and 57 guests
