 Post subject: Toshiba MQ01ABD100 has scratch
PostPosted: October 9th, 2018, 6:34
Hello,,,
Is There any chance to recover partial data from Toshiba MQ01ABD100 hard drive has scratch on surface 0?
Is there any way to disable head 0 and clone rest data?
Best Regards
Expect, the Unexpected
 Post subject: Re: Toshiba MQ01ABD100 has scratch
PostPosted: October 12th, 2018, 16:46
Disclaimer : I'm not a data recovery professional ; but since noone has replied yet, my possibly misinformed comment might elicit answers from a bona fide pro who's going to be eager to correct it, or at least provide you with some keywords to do some more research on your own in the depths of the World Wide Web...
So : isn't this the kind of situation where a "live PCB swap" can do the trick ? From what I understand of that procedure, the idea is precisely that : attach the PCB (circuit board) from the defective HDD to another (healthy) drive of the same model, power it up, at which point it performs self-test procedures and whatnot, relying on data from the system area or “track 0”, then put the system to sleep, then, while still plugged, unscrew the PCB and screw it to the defective drive, then wake up the computer : theoretically, since the drive appears to be the same, and its system area has already been checked, from the system's standpoint it's no longer required to read it, and it may be possible to image the rest... unless there are other defects...
Question : how do you know that “surface 0” has a scratch ?
PostPosted: October 16th, 2018, 15:10
Surface under h0 is clearly seen , by that reason that it is very top surface
Angel Data Recovery
Users browsing this forum: No registered users and 124 guests
