 Post subject: ST1000LM024 HN-M101MBB - BAD DISK AND MRTLAB PROBLEM
PostPosted: October 2nd, 2018, 18:06
When I try to copy the data with DE to an extended image, MRTLAB begins to consume memory until the computer hangs.
It just happened to me with this HDD model.
In addition randomly detects or not the P / N of the HDD, and when it does not detect it I can not make a map of heads.
Apart from these problems with MRTLAB, this disk when it takes a while copying stops copying and I have to turn off and on again.
Does anyone know any parameters that can stabilize the HDD?
Thank you.
 Post subject: Re: ST1000LM024 HN-M101MBB - BAD DISK AND MRTLAB PROBLEM
PostPosted: October 2nd, 2018, 19:16
Possibly he also finds an error when creating the head map, since he reads all the heads well except the number 3 and when there are a few hundred sectors before reaching the head 3 the reading fails, when the rest of the sectors read them at high speed .
PostPosted: October 3rd, 2018, 2:04
What does the terminal show when it is imaging in DE?
PostPosted: October 3rd, 2018, 11:54
I'm sorry I gave it to the client this morning. I needed the data first thing in the morning.
I'm lucky to have a disc with compatible heads. It was the damaged 0x03 head, although under the microscope it looked in good condition.
Next time I will be careful to keep the log files, which can be quite important and I did not keep them until now (badly done by me).
Greetings and thanks for your interest.
PostPosted: October 10th, 2018, 22:00
Thank you.
You won't have problems by following the instructions in this tutorial: http://us.mrtlab.com/filesystem/130.html
More suggestions are welcomed, thanks!
Email: sales@mrtlab.com
Skype: sales@mrtlab.com
QQ;3292109557
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
PostPosted: October 13th, 2018, 10:22
Thank you. The answer is correct but the patch you have is for windows x86 and I have the x64.
Can you provide it?
Users browsing this forum: No registered users and 80 guests
