 Post subject: Anonymus WD 3,5" missing label
PostPosted: October 17th, 2018, 6:36
hi guys, a customer brought me a 3.5 "open WD hdd.The customer claims to have opened the HDD after a fall, the problem is that he threw the hard disk label and I do not know how to find a donor for a head SWAP .What do you recommend? connecting it to MRT this is what I can read: Technology mode key: ..........................: OK
RAM:
Read HDD Info: ................................: OK
Heads number: .................................: 4
Head map: .....................................: F
SA Cyl Count: .................................: 170
Serials Mark: .................................: 0x9D16
Control version: ..............................: 45D0
Zone allocation table: ........................: Err
ROM:
Read Rom Infos: ...............................: OK
ROM Data Size: ................................: 192 Kb
ROM version: ..................................: 05.APE
ROM generation: ...............................: 05.APE
Link table version: ...........................: 04.AD
ROM Firmware version: .........................: 000500AP
ROM Modules:
Flash ROM dir reading: ........................: OK
Switched off heads: ...........................: Yes
Heads number: .................................: 0x4
Heads number in use: ..........................: 0x4
heads map: ....................................: 0,1,2,3
 Post subject: Re: Anonymus WD 3,5" missing label
PostPosted: October 17th, 2018, 7:03
MRT should recognize the family of the drive, thats what you need to start with.
Data Recovery Pakistan
PostPosted: October 17th, 2018, 7:14
Try to find a Kermit with 4 heads ( ex. WD10EAVS-00D7B1 )
Good luck
PostPosted: October 17th, 2018, 7:50
Yes it's Atlantis family it's a 640 gb HDD, this say the customer. The very problem is found a donor for head, I don't know how
PostPosted: October 17th, 2018, 8:00
ROM version is tricky. :)
Atlantis or Kermit.
Good luck
PostPosted: October 17th, 2018, 10:01
PostPosted: October 17th, 2018, 14:31
do not understand what you mean
PostPosted: October 17th, 2018, 14:34
!!??? :lol:
PostPosted: October 17th, 2018, 14:38
Working with Dragfly1 now :
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 2
Head map : .....................................: 3
SA Cyl Count : .................................: 192
Serials Mark : .................................: 0xD916
Control version : ..............................: 53B1
Zone allocation table : ........................: OK
SA SPT : .......................................: 1980
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 192 Kb
ROM version : ..................................: 90.95R
ROM generation : ...............................: 90.96R
Link table version : ...........................: 04.0F
ROM Firmware version : .........................: 00900095
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x2
Heads number in use : ..........................: 0x2
heads map : ....................................: 0,1
SA Module Dir Loading...
Load SA Module dir : ...........................: OK
Configuration reading : ........................: OK
Master Password : ..............................: has not been set
User Password : ................................: has not been set
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: October 18th, 2018, 1:45
Ask your customer about the colour of the label. If it was blue the family is Atlantis, If it was green - Kermit. The heads are the same, only speed is different.
PostPosted: October 18th, 2018, 2:21
I'm not suggesting that you are wrong, but my question would be, if the heads are identical, and if the RPM is different, then wouldn't the heads fly higher in the 7200 RPM drive?
PostPosted: October 18th, 2018, 2:31
Yes it's Atlantis, I wonder, is it enough just the family to find compatible heads? for the seagate disks I had to match with the exact model, and not only. is it different for wd?
PostPosted: October 18th, 2018, 2:36
Good point, as velocity increases so must the pressure. With the increase in pressure, the separation between the head and media can be increased.
PostPosted: October 18th, 2018, 7:51
it's just a stupid mrt bug, it always say in the log that heads are off.
See example:
My firmware database:
PostPosted: October 18th, 2018, 10:35
If the drive passes tests at 7200RPM they make it Atlantis, if not they changes FW to run at 5400RPM as Kermit. You can find the head model at C5 module (as well as family name) or head code at module 0A of ROM.
PostPosted: October 18th, 2018, 12:00
For a case like this, I'd compare the serial number (which should be on a sticker on the bottom of the drive) with other donors of the same family. That'll get you pretty close.
I see in my resources some 00500AP firmware versions with serial numbers around WCASY37... I'd bet yours is close to that, so just aim for an Atlantis family drive with similar serial and you'll probably get the heads you need.
PostPosted: October 19th, 2018, 18:24
This is the serial found on the side : Wmasy3943080
PostPosted: October 20th, 2018, 7:55
Your drive WD6400AAKS WD BLUE
PostPosted: October 20th, 2018, 15:31
@magnetepazzo, you can input the serial number into WD's warranty checker:
http://support.wdc.com/warranty/warrantystatus.aspx
PostPosted: October 21st, 2018, 1:05
Thanks to all for Help.
Users browsing this forum: Bing [Bot], Google [Bot] and 55 guests
