 Post subject: TOSHIBA DT01ACA050 No user area access
PostPosted: October 17th, 2018, 15:47
Hi
I got TOSHIBA DT01ACA050 with a bad head (this HDD have only one physical head P0).
After head replacement, I imaged about 10 GB then it starts giving me an error (black sectors).
The drive gets ready and I have access to SA using Hitachi-IBM-ARM 7210DLE6 and everything looks fine but no access to user area ?? Any suggestion?
Attached SA structure test
SA structure test.7z [2.08 KiB]
Downloaded 647 times
 Post subject: Re: TOSHIBA DT01ACA050 No user area access
PostPosted: October 18th, 2018, 4:03
what if you load translators in RAM, does it give access this way ?
Data Recovery Pakistan
PostPosted: October 19th, 2018, 9:25
I did, still no user access :cry:
PostPosted: October 19th, 2018, 13:05
Maybe head again gone?pls check again, Do you access to the first 10 gig of HDD?
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: October 19th, 2018, 23:49
hamidbid wrote:
Maybe head again gone?pls check again, Do you access to the first 10 GB of HDD?
I tried to access the first 10GB again but no access I get UNC error, but I have access to SA while this drive has only one head ??
PostPosted: October 20th, 2018, 7:22
Then your head gone again!
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: October 20th, 2018, 10:33
If the only head is bad, will i have access to SA?
PostPosted: October 20th, 2018, 15:37
yes it is possible...
Users browsing this forum: No registered users and 85 guests
