 Post subject: WD10JMVW 11AJGS3
PostPosted: November 1st, 2018, 4:14
Hi
I have this drive from wd may passport, it recognised by windows and MRT and even I can do logical test, but MRT dont recognised any information about family and etc, I try to write loader using module 1b 11 and 411 and succesfull to do that, but notting changed, any help guys?
 Post subject: Re: WD10JMVW 11AJGS3
PostPosted: November 1st, 2018, 8:23
Maybe reading is difficult because of issues with pending process, or maybe is SED locked limiting access - without more information any responses will be relatively vague....
PostPosted: November 1st, 2018, 8:53
That's it.
@OP
You have to bypass SED to get access to FW.
PostPosted: November 1st, 2018, 10:00
unknown wrote:
That's it.
@OP
Im new hear ,what is SED, could you tell me how to bypass SED?
PostPosted: November 1st, 2018, 10:49
Spildit wrote:
If you can do logic scan why are you messing with firmware ? Just clone/image the drive if you do need the data ?
If you do have access to LBA at a reasonable speed there shouldn't be any need to gain access to SA unless you want to patch 02, etc ...
I can logical scan , but drive have some bad sectors and during scan its stuck and reset ,in generally hard drive is not fully fanctional!
PostPosted: November 1st, 2018, 14:37
Clone / image it with MRT DE ?
Data is not important, i want to repair drive.
PostPosted: November 2nd, 2018, 14:55
Spildit wrote:
Don't bother. Buy new one.
Can u explain more? what is problem of drive? it not my drive but a client, so I want to repair.
PostPosted: November 2nd, 2018, 15:47
The issue could be many things. But with a 1TB hard drive costing $50, its not worth risking fixing a drive that may (or more likely will) fail again. Besides surely you are charging more than the cost of a new drive to fix a bad one!!
PostPosted: November 2nd, 2018, 21:02
in your country yes but in mine, 50$ for us its like 500$ for you, so its worth to repiar drive for client.
PostPosted: November 4th, 2018, 2:53
Spildit wrote:
You will not be able to fix it. Same way you can't revive dead people ! lol
Let it Rest in Peace. Buy a new drive.
can you explain what is problem? beacuse in first sight it seem not major problem.
PostPosted: November 4th, 2018, 3:09
unknown wrote:
That's it.
@OP
how to bypass SED ?
PostPosted: November 5th, 2018, 4:39
this is log from mrt
is there any hope ?
i cant logic scan anymore
