 Post subject: WD2000JD
PostPosted: March 22nd, 2005, 20:36
i got wd2000Jd drive, and trying to copy to other media. it is very very slow....... copy few thousands sector ok but then just slows to crawl, any help ?
FUZZY
 Post subject:
PostPosted: March 22nd, 2005, 20:38
SMART attributes corruption.
 Post subject:
PostPosted: March 23rd, 2005, 1:24
how to fix that
Data Digger
 Post subject:
PostPosted: March 23rd, 2005, 10:45
I know that can be fixed with PC-3000. I don't know if other utilities can fix this problem.
 Post subject:
PostPosted: March 23rd, 2005, 11:47
Did you try it? JD - SATA model, if we try use SiI3112A to access drive firmware it's impossible - something cut vendor specific command.
So we can get trouble here...
best regards, vi, http://pchdd.narod.ru
 Post subject:
PostPosted: March 23rd, 2005, 17:00
I 've got a bridge board to attach SATA drive to PC3k. It works with WD, but extremely slow, and doesn't work with maxtor. I'm examining the problem and in case I find something I let U know.
 Post subject:
PostPosted: March 23rd, 2005, 23:57
I did check with pc-3000 , smart is ok sa is perfect. i am cloning within pc-3000 .data extractor.. but slow like crazy. like realy realy realy realy slowwww..... any suggestion to speed up will help alot.... using sata to ide adapter....
Data Digger
 Post subject:
PostPosted: March 24th, 2005, 0:39
Sometimes you just have to live with it, man. :wink:
 Post subject:
PostPosted: March 24th, 2005, 5:37
Very funny, what acelab itself say what they have trouble with SATA WD, but SATA Maxtor work perfectly ;)
Not all bridge can help ;)
 Post subject:
PostPosted: March 24th, 2005, 6:21
They recommended Granitedigital's bridge, I ordered, I got it, but doesn't work perfectly. I am trying factory mode commands in a debugger and there are strange things happening...
WD works just slow, really very ... slow.
By the way I need modules for WD 2500JD too.
maybe 2500JB would help as well.
 Post subject:
PostPosted: April 2nd, 2005, 4:19
Pepe,
I have a working WD2500JB - 00FUAO
Could it help ? ?
Users browsing this forum: No registered users and 101 guests
