 Post subject: Samsung ROM corrupted. Please Help.
PostPosted: November 7th, 2018, 4:08
I am looking for a Rom to Samsung HM321HI ver. 2AJebq4
Does anyone have a working ROM?
I add the original rom from the PCB.
Regards,
Michael
samsung_oryginal.zip [177.41 KiB]
Downloaded 409 times
 Post subject: Re: Samsung ROM corrupted. Please Help.
PostPosted: November 7th, 2018, 5:23
What error do you see in terminal?
Here is the output of my ROM analysis tool:
Verifying Samsung SpinPoint ROM:  samsung_oryginal.bin
Checksum of Boot Block header = 0xAE  - OK
Checksum of Boot Block (Actual/Expected) = 0x672C / 0x672C  - OK
Searching for FIPS block (expected checksum = 0x0000) ...
Found FIPS text string at 0x003000
Checksum for 0x0800 byte FIPS block = 0x0000  - OK
Possible 0x0800 byte FIPS block at address 0x003000
Searching for FLASHTBL ...
Found FLASHTBL text string at 0x004024
Parsing FLASHTBL at 0x004000 ...
ID Byt1 Byt3    Size   ROM address range   RAMaddrs  Cksm (Exp/Act)
00  00   FF         0 FFFFFFFF                    0            N/A
01  02   FF       320     4000 - 431F      FFF04000  B3 77   - BAD (Note 2)
02  08   FF       5DC     4320 - 48FB      FFF04320  55 55   - OK
03  00   FF     13EAC     4900 - 187AB            0  74 75   - BAD (Note 3)
04  01   FF      2B98    187B0 - 1B347        14D00  00 57   - BAD (Note 1)
05  00   FF       C70    187B4 - 19423      4000000  7A 7A   - OK
06  00   FF       228    19428 - 1964F      4005C00  F8 F8   - OK
07  00   FF     19A40    19654 - 33093     10000300  FE FE   - OK
08  01   FF     1B4B4    33098 - 4E54B     1002E300  00 BB   - BAD (Note 1)
09  00   FF      2A4C    3309C - 35AE7     18052300  9B 9B   - OK
0A  00   FF      12EC    35AEC - 36DD7     200164F0  97 97   - OK
0B  00   FF       1D8    36DDC - 36FB3     FFFE1000  92 92   - OK
0C  00   FF       DD0     1800 - 25CF      FFF01800  07 08   - BAD (Note 3)
0D  02   FF         0 FFFFFFFF             FFF04000            N/A
0E  08   FF         0 FFFFFFFF             FFF04320            N/A
0F  20   FF         0 FFFFFFFF             FFF01800            N/A
10  00   FF         0 FFFFFFFF             FFFC0000            N/A
11  00   FF         0 FFFFFFFF             200164F0            N/A
Searching for SERVOTBL ...
Found SERVOTBL text string at 0x037024
Parsing SERVOTBL at 0x037000 ...
00  02   FF       100    37000 - 370FF     FFF37000  17 68   - BAD (Note 2)
01  00   FF      8E58    37104 - 3FF5B            0  51 51   - OK
02  00   FF       814    3FF60 - 40773      4000100  18 18   - OK
03  00   FF       2A0    40778 - 40A17     FFFE1000  6F 6F   - OK
04  02   FF         0    36FFF             FFF37000            N/A
Size            - size of module in ROM expressed in bytes
ROM address     - absolute address range of module in ROM
RAMaddrs        - load point of module in RAM
Cksm (Exp/Act)  - Expected Checksum / Actual Checksum
Note 1:  The address range of affected module may conflict with another module,
          in which case this is probably a false negative.
Note 2:  If this module is the FLASHTBL or SERVOTBL, then this is most likely
          a false negative.
Note 3:  This may or may not be a genuinely BAD module. Examine the checksum
          of the first half of the ROM. If 0x0000, then module is probably OK,
          otherwise it may or may not be bad. Also examine the "adjusted"
          checksum, if applicable.
Note 4:  The address range of the module is outside the limits of the ROM.
PostPosted: November 7th, 2018, 8:30
Dear fzabkar,
I did not connect to the terminal. Drive does not spin.
I tried to copy the FIPS section from a working rom but it does not work.
PostPosted: November 7th, 2018, 9:50
  Information about dump
   Dump size............................... : 524288 bytes
   Firmware checksum....................... : Ok
   FIPS offset............................. : 0x00003000
   FIPS size............................... : 4096 bytes
   FIPS checksum........................... : Ok
   Firmware type........................... : Main Code
   Original name........................... : 2AJebq4M.143
   Platform Id............................. : 0x2B
   Head map................................ : 0, 1
Mikippp
2AJebq4M_d43.zip [176.91 KiB]
Downloaded 410 times
PostPosted: November 7th, 2018, 10:26
Dear Mikippp,
Your rom works. Thank you very much for your help.
PostPosted: November 7th, 2018, 14:49
ISTM that the FIPS size is 2048 bytes, not 4096.
Verifying Samsung SpinPoint ROM:  2AJebq4M_d43.bin
Checksum for 0x0400 byte FIPS block = 0x3A94  - BAD
Checksum for 0x0C00 byte FIPS block = 0xFE00  - BAD
Checksum for 0x1000 byte FIPS block = 0xFC00  - BAD
03  00   FF     13EAC     4900 - 187AB            0  74 74   - OK
          a false negative.
