 Post subject: HGST HUH721212ALE600 Firmware / identify in pc-3000
PostPosted: November 10th, 2018, 23:32
Ultrastar DC HC520 He12
Identifying the device ...
Any suggestions? I'm not even sure what to choose from the device category ...
i'm fairly new to PC-3000 -- and I have to admit
- Determining the family of device with just a short alpha-numeric moniker for the family doesn't make it obvious.
Is there a list that lets me identify or classify them ??
 Post subject: Re: HGST HUH721212ALE600 Firmware / identify in pc-3000
PostPosted: November 10th, 2018, 23:51
That model is fairly new. No supported in PC3000, yet.
Can try entering the utility using one of the other families, though not sure if it will work.
PostPosted: November 11th, 2018, 1:27
Can you upload a ROM dump? I have analysed the ROM from a HUH728080ALE600 (WD80EFZX-68UW8N0), so I'm expecting that it will be similar. AFAICT, HGST has also publicly released the VSC which allows reading of the SA. However, I don't know if a Super-ON command needs to be issued beforehand. I can help with this if you know how to use an ATA terminal.
FWIW, the WD80EFZX-68UW8N0 is an Aries HC8.
PostPosted: November 11th, 2018, 14:37
I tried. (I lose) . :(
how do i get a ROM dump?
is there any chance HDDsurgery doesn't appear to have it.
could someone else have it?
i have good drive connected as well as bad.... yet, i still can't get in.
PostPosted: November 11th, 2018, 17:53
(Helium filled HGST) WD80EFZX-68UW8N0 ROM (structural analysis):
http://www.hddoracle.com/viewtopic.php?f=153&t=2549
Users browsing this forum: No registered users and 93 guests
