Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD5000BMVV
PostPosted: March 7th, 2012, 22:05
I believe that if the drive is not spinning after swapping the U12, then the USB PCBs are not compatible.
PostPosted: March 19th, 2012, 5:34
I can someone clear this doubt for me:
On the 2060-701675-001, wich are the ground pins?
I think it's E2-E7-E46-E47.
Is this right?
ACELab partner
PostPosted: March 19th, 2012, 10:30
A multimeter will be able to tell you.
PostPosted: March 19th, 2012, 13:58
unknown wrote:
Fact : Just fixed one -few minutes before- with PCB # : 2060-701675-004 REV P1 ( USB interface ) with donor PCB # : 2060-771672-004 REV A ( SATA interface ) :)
the drive had some damaged modules so I replaced the PCBs and worked on SATA interface after swapping U12 only ( theres no place for U14 on the SATA PCB ) then after fixing the drive back the USB PCB, and the drive now is working like a charm.
Well,
What all Mods Were Damaged ?
PostPosted: March 20th, 2012, 8:26
Amarbir wrote:
Well, What all Mods Were Damaged ?
The drive were suffer from slow responding problem, then translator then reset smart then everything went successful.
PostPosted: January 30th, 2013, 1:32
same here...
Patient was spinning fine but with the donor after swapping U12 doesn't even spin.
Patient PCB: 2060-701675-001
Donor PCB: 2060771672-004
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: January 30th, 2013, 2:35
shahij wrote:
same here...
Not every advice is actually an Advice, and not everything you read is actually true,
some helps n some kills.
and for sure this is one of them.
it is like while you are reading a book and skipping the 1st. few chapters and jumping to the END of the book
looking for the Conclusion.
good luck
PostPosted: January 30th, 2013, 3:03
einstein9 wrote:
shahij wrote:
same here...
good luck
YES "TRUE"
yes, what is in your mind if things are followed !!! yeah, everything was done right as required... To clarify...
I require to access SA (converting into SATA was essential), tried the donor board as mentioned for converting into SATA, but unsuccessful due to IT STOPS SPINNING with DONOR Board, but things are taken back to USB and SPINS file like before.
Is it happening for PCB incompatibility or something else? (MCU are same into the both PCB)
__________
THANK YOU
SHAHI
PostPosted: November 12th, 2018, 13:06
Reviving an old thread here, does anyone know which SATA PCB is compatible with the USB PCB 701675-002 Rev P1?
Have tried putting the ROM on a 771672-004 Rev A and it won't spin up.
PostPosted: November 12th, 2018, 13:46
ATA registers?
Maybe corrupted ROM/Pre-amp
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 82 guests
