Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: OCZ Vertex 4 128gb UART Recovery method?
PostPosted: November 29th, 2018, 21:32
I don't think it will change anything, but could you measure the voltages at each pin of U3 (near V3)? I don't know what this chip does, but I'm wondering if it is a power supply monitor.
PostPosted: November 30th, 2018, 4:02
ykohavix wrote:
can PC-3000 be used by every one ?
Sure, if you have the $$$$$
PostPosted: November 30th, 2018, 8:23
U3 Pins voltage readings (start from white arrow) pin 1-6 anti-clockwise order:
1=1.79
2=0.5mv
3=3.06
4=3.17
5=0.5mv
6=3.28
PostPosted: November 30th, 2018, 14:50
ICBW, but U3 appears to be a dual voltage monitor with individual reset outputs on pins 3 and 4. Pins 1 and 6 appear to be the monitored voltages, namely 1.8V and 3.3V. ISTM that the outputs are OK.
PostPosted: December 1st, 2018, 7:10
I got another working 64GB unit, excat same Vertex 4 product.
Might worth open it and compare at certain point that can lead us to solution?
Or the "CPU Panic mode / FW fault" will be the case no matter what we do?
PostPosted: December 1st, 2018, 14:38
I don't think that will help us.
You could experiment with the firmware test point and observe how your good drive behaves when this test point is shorted to ground at power-on. Then check whether the data are still intact. This will at least tell you whether or not the controller is brain dead.
You might also like to connect a USB-TTL serial adapter to the Tx/Rx UART pins and see whether there is any diagnostic output.
Users browsing this forum: No registered users and 104 guests
