 Post subject: wd15eacs-11bhub0 Zone allocation table : error
PostPosted: December 1st, 2018, 12:35
Hi guys, I have this hdd that takes a long time in BSY state. Connected to MRT i see Zone allocation table: error. I tried to load ldr that a friend of the forum gave me, but at first it was not loaded. I then disabled module 02, turned off and on again and so I managed to load LDR after loading ldr the hdd was recognized as 310.89 GB but still remains inaccessible. I made a complete backup of the modules and I noticed that the 0D module of the ROM and 0002 of the SA had a read error. Tips ? Thank you
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 1
Head map : .....................................: 0
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: 7412
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 256 Kb
ROM version : ..................................: 25.12E
ROM generation : ...............................: 25.12E
Link table version : ...........................: 0B.36
ROM Firmware version : .........................: 00250012
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number : .................................: 0x6
Heads number in use : ..........................: 0x5
heads map : ....................................: 0,1,5,6,7
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
Load LDR(0x11), As permanent overlay...
Send Data(0x11) : ..............................: Err(Send Data Fail)
Load LDR : .....................................: Err
Load LDR(0x5C), As permanent overlay...
Close 02 module ...
Get 02 access information : ....................: OK
Check 02 access data : .........................: OK
Close 02 module : ..............................: OK
Load LDR : .....................................: OK
load 01...
Get 01 module from HDD : .......................: OK
Load module list : .............................: OK
Zone allocation table : ........................: OK
SA SPT : .......................................: 1980
 Post subject: Re: wd15eacs-11bhub0 Zone allocation table : error
PostPosted: December 1st, 2018, 17:19
Have you solved slow responding and then re-activated module 0x02?
That gives you error when reading the module 0x02, I think it is because of a modification made by the MRTLAB in the ROM and gives that error. At least that happens when you deactivate the 411 module.
PostPosted: December 1st, 2018, 18:37
if I do not disable module 02 I do not get access to the list of modules, the module 411 does not disable it because I think that on this hdd would have no effect, I know it is used on the most recent disks. however I did not solve it. honestly I do not know what to do, I accept suggestions
PostPosted: December 1st, 2018, 18:43
Can you upload a copy of the ROM?
Does it make strange noises?
Have you tried to solve slow responding?
PostPosted: December 1st, 2018, 18:56
I do not hear strange noises seems to start smoothly, I launched the slow disk resolution command but it crashes.
Rom are in atachment.
ROM.rar [226.93 KiB]
Downloaded 376 times
PostPosted: December 1st, 2018, 19:06
I get an error when opening the rom file !!!
PostPosted: December 2nd, 2018, 8:45
Strange, I recopy it tomorrow in lab . Thanks
PostPosted: December 2nd, 2018, 14:24
this is new dump, i have open it with winhex, regular
ROM.rar [227 KiB]
Downloaded 349 times
Users browsing this forum: No registered users and 364 guests
