 Post subject: Need help to restore a bricked WD PCB
PostPosted: December 25th, 2018, 13:42
Hello to all.
I am trying to fix a PCB, and flash the correct ROM too it, if anyone is willing to help me i am offering $100us.
Please PM if you are interested.
Thanks.
Data Recovery in the Dominican Republic
https://www.recuperamidata.com/
 Post subject: Re: Need help to restore a bricked WD PCB
PostPosted: December 25th, 2018, 16:51
Buy a complete working donor HDD, flash the patient's ROM to it, then transfer the donor's PCB to the patient HDD. That should cost much less than US$100.
PostPosted: December 25th, 2018, 17:57
I know, still would like some help to do the process faster.
PostPosted: December 26th, 2018, 8:03
With PC3000 you can write ROM using COM port.
ACELab partner
PostPosted: December 26th, 2018, 9:20
I know, but... its to do it manually, also needs to be done using boot code mode, cause PCB is bricked.
PostPosted: December 26th, 2018, 16:07
Good to know that you have an ebay store, will check yiur store.
Thanks.
Spildit wrote:
A new PCB from any decent provider should cost $50 USD or less with free ROM programming assuming you do still have the original ROM code.
Can you post the PCB number ? Both the sticker and the number engraved on the PCB ?
I will check if i do have a PCB for you and i will copy the ROM for you (assuming you do have original ROM file).
PCB from me is $5 USD + $10 USD shippiing costs (you can check my eBay store) as long as i do have the PCB that you need (i do have many WD PCBs).
:D
PostPosted: December 27th, 2018, 8:54
Hello
Hi Spildit the PCB# is 2060-701444-004 REVA, good to know that you have PCB to sell.
Cheers.
PostPosted: December 27th, 2018, 16:37
Spildit wrote:
Happy Happy !!!
This time i'm goint to earn some $$$ from LoboX.
Oh ... and don't forget the positive feedback !
:D
Hahaha don't you will get the positive feedback :)
PostPosted: December 29th, 2018, 21:18
Heya Spildit
Haven’t been able to sit and do it actually, still need to try and unbrick the PCB.
Thanks.
Spildit wrote:
So ... did you end up fixing up the PCB with U-Command or something like that ?
You didn't buy the one that i'm selling so i guess that (once again) you either did get away with a free fix or you were not able to recover the drive ?
cron
