 Post subject: Burnt Chip on WD PCB
PostPosted: December 29th, 2018, 17:01
I have a WD800JB-00JJA0. I hooked it up to a faulty external drive enclosure and burnt up something on the PCB. It looks like it’s “L4”. It looks melted. Possibly C62, too. Any idea how I could fix this? Or at least temporarily use it to get the data off?
 Post subject: Re: Burnt Chip on WD PCB
PostPosted: December 29th, 2018, 19:31
Sorry, I made the post then kept getting an SQL Error when trying to upload a picture. Here is a picture.
PostPosted: December 29th, 2018, 23:09
It appears that the failed inductor (L4) is in series with the +5V supply. Therefore I expect there is further damage, possibly to the preamp. :-(
PostPosted: December 29th, 2018, 23:57
Would this mean I would need to replace the board? Or is the entire drive likely dead?
PostPosted: December 30th, 2018, 2:28
If the preamp is damaged, you will need to replace the head stack assembly. If it's just the PCB, a PCB swap (and ROM swap) will do the trick.
PostPosted: December 30th, 2018, 10:25
Spildit wrote:
I wiuld replace the PCB + ROM chip (or ROM CODE).
If the drive just clicks the pre-amp (inside the drive) is gone and if you do need to recover the data out of the drive you will need to send it to a professional data recovery firm.
DO NOT OPEN THE DRIVE YOURSELF outside a HEPA 100 aseptic room ...
Thank you. I will try a new PCB with a transferred ROM chip. Do you think it's safe to plug my device in now to a proper connection and see if it spins up or does anything?
PostPosted: December 30th, 2018, 14:08
Do you think it would be safe to power up the drive again with a proper connection to see if it spins?
PostPosted: January 1st, 2019, 20:57
Yes. No if there is a head crash.
http://www.datasaversllc.com
PostPosted: January 1st, 2019, 21:02
I ended up trying to plug it in again. Nothing happened at all. No noise or anything. I'm going to get a replacement board to see if that fixes it.
Users browsing this forum: Google [Bot] and 44 guests
