 Post subject: Samsung HD161HJ Detect Problem
PostPosted: January 2nd, 2019, 13:08
Hi
Detect Problem
in treminal shows
 SPW 3.0G LinkOk!5V: 05030
SpnOk
spd:  0000 0000 0000
H: +00000
ADC: 0006
DAC: 7687
SK C: 0001AF85
ENG>SRV>
  SvoTbl Loaded
  CL 2306 CM 2377 SL 0E7B SM 0E76
  BD
  FdtTbl Loaded
Data Not important.
 Post subject: Re: Samsung HD161HJ Detect Problem
PostPosted: January 4th, 2019, 3:03
Spildit wrote:
siamak5561 wrote:
Data Not important.
Then buy a new drive.
extracly :) :)
DATA RECOVERY SERVICE VIETNAM
Cứu dữ liệu ổ cứng| Cứu dữ liệu máy chủ |Phục hồi dữ liệu
PostPosted: January 8th, 2019, 12:38
Spildit wrote:
siamak5561 wrote:
Data Not important.
But I want to repair drive, look in your country maybe not worth to repair drives but in mine its really worth to repair drives.
PostPosted: January 8th, 2019, 18:03
Spildit wrote:
What do you mean by "detect problem" doesn't ID at all ? Does ID but doesn't scan LBA ?
Do you have any sort of firmware tool to play with the drive firmware ? At least something like SeDiv or SHTR ?
Did you check PCB ? Did you check if there are other problems like junky PSU ?
Does the drive click or make strange noises ? When you power on the drive do you ear the heads moving to read MC ? DO NOT OPEN THE DRIVE ...
etc .. etc ....
More info would be required.
Not ID at all
I Have MRT Ultra
no strange noise
PostPosted: January 9th, 2019, 4:58
Spildit wrote:
MRT is kind of "Junk" to work with Samsung .... If you don't have PC-3000 the best that you can try is SHTR ...
Register status show what ? BSY ? Error ?
Can you enter terminal commands like pressing ESC ?
Do you have identical model to hot swap ?
Can you test MC with MRT ? Can you access MC and backup modules and ROM with MRT or drive is stuck at BSY, etc ?
In terminal ONLY DBG mode, and no any other access
Users browsing this forum: Google [Bot] and 66 guests
