 Post subject: Connecting Hard disk of different laptop
PostPosted: January 17th, 2019, 11:47
Hello guys!
I am trying to connect Compaq Laptop Hard Disk SATA to Dell Inspiron for Compaq's data recovery purpose through data cable/ USB port. But, the Dell is not detecting the Hard Disk. Can someone direct me the steps to detect it? Otherwise what can be the fault in the Hard disk? :?:
 Post subject: Re: Connecting Hard disk of different laptop
PostPosted: January 18th, 2019, 3:06
Spildit wrote:
Maybe the drive is locked with ATA password ?
Did you old laptop used BIOS password ?
Also can you test the drive directly on another system by SATA ?
What is the full model of the drive ? Can you ear it spinning at all when you connect it using the adaptor ?
No, there was no password.
I don't know whether Dell inspiron is SATA or Ide .I guess it is not SATA. No there is no spinnning . Model name is :
WD1200BEVS.
PostPosted: January 18th, 2019, 9:09
So it's sata!
Check in the laptop bios to see if the drive is detected.
Users browsing this forum: hass and 309 guests
