 Post subject: 100717520 short pin ?
PostPosted: January 21st, 2019, 11:57
Hi guys someone know short pin for this PCB ? thanks
 Post subject: Re: 100717520 short pin ?
PostPosted: January 21st, 2019, 12:16
Don't be afraid to post a picture of the board.
PostPosted: January 21st, 2019, 16:14
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
PostPosted: January 21st, 2019, 16:51
You have right bro. :-)
PostPosted: January 21st, 2019, 18:24
If you had Googled your topic title, and examined the first sub-item ("Short Point Seagate ST3000DM001 - 100717520") you would have found your answer.
PostPosted: January 21st, 2019, 18:40
One channel reading the other writing channel.
He can not tell you exactly which is which.
I think they are marked in black, the others give 0.8 volts with the isolated PCB.
Hope this can help you
Users browsing this forum: ccc, Google [Bot], pepe and 58 guests
