 Post subject: Unbranded Flash with Chipsbank Controller
PostPosted: February 1st, 2019, 15:00
This flash drive gets the correct power in the correct places, but still not seen. I presume we my be able to get to the chip pinout via the via's on the controller side? Anyone seen one before?
 Post subject: Re: Unbranded Flash with Chipsbank Controller
PostPosted: February 1st, 2019, 16:29
Yes, you must connect from controller side.
PostPosted: February 1st, 2019, 16:32
Is there a template, or just experience knowing what the pinout is?
PostPosted: February 1st, 2019, 17:12
Find datasheet of the controller, there will be everything you need.
PostPosted: February 1st, 2019, 17:54
Perfect, thanks.
cron
