 Post subject: Need ROM Samsung 1TB F3 Family | HE103SJ/D FW: 1AJ30001
PostPosted: January 29th, 2019, 12:39
Anyone has this ROM ?
Drive is Samsung 1TB
Model: HE103SJ (DELL OEM)
The symptoms are that drive refuse to spinup with original pcb+rom, have tried to swap rom to donor pcb but same. drive only spin up with donor pcb + donor rom. So i guess rom is faulty.
Information about dump
Dump size............................... : 524288 bytes
Firmware checksum....................... : Ok
FIPS offset............................. : 0x0007F000
FIPS size............................... : 1024 bytes
FIPS checksum........................... : Ok
Firmware type........................... : Main Code
Original name........................... : 1AJ63uhM.126
Platform Id............................. : 0x1A
Head map................................ : 0, 1, 2, 3
thanks for checking.
Data Recovery Pakistan
 Post subject: Re: Need ROM Samsung 1TB F3 Family | HE103SJ/D FW: 1AJ300
PostPosted: February 8th, 2019, 17:19
Can you upload your faulty ROM? I have a tool to check it for consistency.
PostPosted: February 11th, 2019, 9:19
Luckily I found a close drive, did a hotswap and adopted the new ROM, the case is closed. But for R&D if you want i can upload it ?
PostPosted: February 11th, 2019, 14:42
Yes please.
Users browsing this forum: No registered users and 84 guests
