 Post subject: need to tranfer a PCB bios from one PCB to another
PostPosted: February 18th, 2019, 7:57
I need to tranfer a PCB bios from one PCB to another. I've seen tutorials with soldering, but is there a way to do without?
Like a tool on my pc to save the bios of my not working PCB and ré-inject the save into my New PCB?
Would I need special cable or anything?
By the way, my PCB is model 2060-771737-000 and the drive in it is WD5000BMVW-11AMC50
I have tried to change the pcb but the drive still didn't work and learnt that I had to change the bios PCB from the old to the new PCB.
Thanks a lot to anybody who can Help!!
 Post subject: Re: need to tranfer a PCB bios from one PCB to another
PostPosted: February 18th, 2019, 11:43
Not easily.
It may be possible to use something like WDMarvel software to save the ROM via the serial port, I don't use that software so I have no idea. Probably Spildit will be able to advise there?
Firstly, what makes you think the PCB is faulty? Is the drive totally 100% dead (no spinning, clicking or buzzing)??
Secondly, if it really is a PCB fault then your local electronic guy should be able to do it. AT YOUR RISK.
PostPosted: February 20th, 2019, 7:12
RESPONDING TO PCIMAGE=> Thanks a lot!
pcimage wrote:
Not easily.
The drive is not seen anymore. It's an external 3.5 drive in a box, I haven't tried another adapter because it's a special drive WD5000BMVW-11AMC50 (see model) and I cannot put another dam standard adapter to try to see if drive is seen (anybody knows a way?°
PostPosted: February 20th, 2019, 7:16
RESPONDING to Spildit : Thanks, you look like an ace! ! SO advanced that when you speak it seems chinese to me, I'm trying to understand and decipher the data you have sent me.....I'll try to test but will have question I think....
If this is a WD PCB with EXTERNAL ROM chip .....
What is an external ROM chip? (sorry english is not my native tongue)=> The HDD model is in an external box enclosure, all I can say
PostPosted: February 20th, 2019, 7:35
The big question is ....Why do you think the problem is PCB related ?
Indeed you are write, I don't know if the PCB is related to the pb, I assume it is it's a theory.
I cannot test another "standard" SATA adaptor because the sata adaptor is integrated on the PCB mainboard
the link to the image is here:
https://www.ebay.fr/i/172811301290?chn=ps&dispItem=1
So by deduction: if I change the part, I have at least 50% chance (even more maybe) that it will work
PostPosted: February 20th, 2019, 7:43
Also spildit, Please tell me, concerning your 3 solutions:
What is easiest solutions? advantage/disavantage of each? What is the one with less cost.
Also I have another technical question (i've done another forum) concerning an Hard Drive recovery i've done I need an ace's advice
Users browsing this forum: Google [Bot] and 57 guests
