 Post subject: How to Fix Bad Sectors that NOT shown by Surface test
PostPosted: February 25th, 2019, 5:18
Hi everyone
i usnig Hard Disk Sentinel 5.01 PRO
that Program says that " there are 4 Bad sector in the Hard that cause reduce of the Health to 94%
But in the Surface Test no Any Bad Sectors , And Attribute #5 Reallocated Sector Count 0 100 100
how to overcome this problem ?
and any way to change values of SMART like offset them for example ?
thanks
 Post subject: Re: How to Fix Bad Sectors that NOT shown by Surface test
PostPosted: March 5th, 2019, 0:44
If the data is not important, or is properly backed up, you could run a complete write scan; if those sectors have been marked as bad because of an inconsistent state (which can happen for instance when there's a power failure during a write operation), overwriting them should remove them from the “pending sectors” list – if that's indeed where they appear currently. Posting a screenshot of the “SMART” tab (not the “overview”) might help to refine the diagnosis.
cron
