 Post subject: Toshiba DT01ACA100 - can't read in DE. Does read in utility
PostPosted: March 12th, 2019, 12:51
Just got stuck with this Hitachi drive. It had one bad head. I got 100% of the other. Changed heads, and it was reading well for a while. It stoped at some point and now i can't read anything more in DE. But i can read the same sector in utility. Quick test shows that this head can read. The only problem i found is SMART. One copy is bad. And i can't check SMART at all. But it was the same earlier. All crucial modules are ok escept AMPM, HLR1,HLR2 which are yellow. Any hints?
odzyskiwanie danych
 Post subject: Re: Toshiba DT01ACA100 - can't read in DE. Does read in util
PostPosted: March 12th, 2019, 13:29
I am not sure if it supports this particular model, but did you try to read with the Active Utility?
PostPosted: March 12th, 2019, 13:51
I did. I found that it's heads problem. It doesn't read in donor too. My mistake was that i took sector address from DE and put it in utility. I forgot that it's not the same when you use physical sector size, not logical. :roll:
odzyskiwanie danych
Users browsing this forum: No registered users and 94 guests
