 Post subject: WD5000BPVT-24HXZT3
PostPosted: March 8th, 2019, 5:24
drive spins normally. FW backup is ok by all four heads.
But in DE shows by headmap only heads 0,1,2. On begining read at speed of 45mb/s, then stop reading.
Is it normal that show only 3 heads in DE, but under WD utility 4 and also read normaly from SA.
Thank you
 Post subject: Re: WD5000BPVT-24HXZT3
PostPosted: March 20th, 2019, 16:47
I change heads, symptoms remain.
FW backup done without problems(rom, modules and tracks) with normal speed
I create new task in DE. Build headmap,, but headmap shows only heads 0,1,2.
WD marwell shows 4 heads and also read from all of them.
I check donor.Under WD marvell show 4 heads and also under DE shows 4 heads.
When I start reading under DE it reads first 890000 LBA(heads H0, H1, H2) with speed 45MB/s. After 890000(still under H2) stop reading.
I try to read also from back without any result.
Any suggestion
Thank you
PostPosted: March 20th, 2019, 16:57
Any suggestion
Thank you
It might have 4 physical heads, but only 3 are being used. Can you send some screenshots of the WD Utility window and also a screenshot of the ROM head map screen.
PostPosted: March 21st, 2019, 2:18
Thank you DDRecovery for replay.
PostPosted: March 21st, 2019, 11:01
Maybe it was at another data recovery company and they tweaked something so it wouldn't work (like changing the head map in ROM).
PostPosted: March 21st, 2019, 11:50
I know owner, and he didn't say that he was in another shop.
Modules from begining to 63 was read by all 4 heads, from 115 only with 0,1
Tracks was read by 0 and 1 from Cyl -256 to Cyl -65
PostPosted: March 21st, 2019, 12:32
Thank you
This model has really crazy HM, to cut it short here is what i do:
IF No one touched it before you then you do the following:
-Forget the last Head now.
-Clone/Dump H0 then go for H1 leave the last heads then Scan for Part.
Am assuming the last head has issues (the third) and my best guess this drive has 3 heads only..
change heads if needed.
let us know later about the results..
Good luck
PostPosted: March 21st, 2019, 12:53
Thank you Jared and Einstein9 for help.
I try to image by selective head without success.
It read from 0 to 890049. I can see that read from head 0, then from head 1 and finally from head 2. When come to 890049 with head 2 stop reading.
Behaveor with original heads and with donor heads is same.
If I raw recovery what it read I can see files.
Also under DE it show drive with all partitions, but then is problem to access partitions data.
PostPosted: March 22nd, 2019, 0:10
The drive belongs to ZEPHYR_N family. They have capacity of 750GB for 4 logical heads and 500GB for 3 logical heads.
So your drive has one head cut at factory....
PostPosted: March 22nd, 2019, 17:15
Banned User
Try to do reverse copy mode and see what happens.
PostPosted: March 23rd, 2019, 3:39
try to rebuild ROM from SA and see the difference of active heads...
Data Recovery Pakistan
PostPosted: March 23rd, 2019, 15:16
Hello
Thank you for all your suggestions.
I try with another PCB. Now I get also under DE all four heads.
But still no progress with reading.
PostPosted: March 24th, 2019, 9:17
Banned User
Have you attempted to read via PIO mode (Use hardware retries) and also increase the timeout to something like 10000ms? Sometimes this can help.
[spam removed]
PostPosted: March 24th, 2019, 9:43
Hello cpm0088,
I test all heds under PC3000 and all passed test.
I can Access cestors from 0 to 899263(that is the amount of data, which DE read. After 899263 sectors are not accesible.
PostPosted: March 24th, 2019, 10:07
Banned User
Check the G-List and P-List and see if theres anything unusual, could even be translator is messed up.
PostPosted: March 25th, 2019, 2:34
I try also with head editing in RAM, but still I'm unable to get Access to user data
PostPosted: March 25th, 2019, 3:53
@jerovsek, could you upload your ROM? I'm curious as to why one tool reports 4 in-use heads while the other reports 3. Would it be worthwhile to compare the patient and donor resource dumps?
PostPosted: March 25th, 2019, 4:15
Hello Mr. Zabkar,
I work with PC3000.
WD Marwell utility show 4/4 heads with original PCB. In Data Extractor whiich is part of PC3000 it show only 3 heads.
When I write ROM and ROM moduls to donor PCB WD Marwel show 4/4 and also under DE I see 4 heads.
But with original PCB or with donor PCB I can Access only sectors from 0 to 899263.
It looks like something is wrong with translator.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1098
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 65.0AE
ROM F/W version......................... : 0065000A
Overlay F/W version..................... : 65.0AE
Servo F/W version....................... : 05.0C
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
PostPosted: March 25th, 2019, 4:31
Could it be that the original headmap was 0,1,3? Like that head 2 can't read nothing,
Can you read from the other heads after that LBA? Can you read last sector?
Have you tried a translator regen?
ACELab partner
PostPosted: March 25th, 2019, 4:48
Hello PCLab,
thank you.
As I already write I can Access only this sectors. If I try to read any other sector Access to it is not possible.
In DE it reads from heads 0,1,2
Users browsing this forum: Google [Bot] and 69 guests
