 Post subject: Samsung HD321LJ Donor
PostPosted: March 21st, 2019, 6:48
Online
I'm looking for a long time (about a year) for a donor for this drive but cannot find one.
HD321LJ does not seem to show up.
Does anybody know of any cross compatible drives for this one?
Thanks.
 Post subject: Re: Samsung HD321LJ Donor
PostPosted: March 21st, 2019, 10:00
I might have DONOR in stock
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: March 21st, 2019, 10:58
Try using a HD501LJ instead. Yours was probably intended to be a 500Gb in the first place and was downgraded when one platter surface was no good. Even if you did find another HD321LJ it might be missing a different head than yours. So you should be buying the 500Gb version anyway. That way you're guaranteed to get all heads.
PostPosted: March 21st, 2019, 12:36
Online
Thanks for the tip. I found a couple of HD501LJ. In a few days I'll come back with a result.
PostPosted: March 28th, 2019, 5:51
Online
I made the swap with heads from an HD501LJ I found online.
Drive starts ok, no strange sounds, don't spin down, even gets ready.
If i try Read ID, or any user sector gets BSY.
Terminal looks like this:
SPW 3.0G LinkOk!SpnOk
spd: 0000 0000 0000
ADC: 0006
DAC: A393
H: +00000
Any advice ?
PostPosted: March 28th, 2019, 7:05
Banned User
Must be media problems (bad sectors)
PostPosted: March 28th, 2019, 10:02
Have you checked the preamp version between both?
ACELab partner
PostPosted: March 28th, 2019, 12:51
Online
Case closed. Donor heads put back in Original drive do not work anymore.
It seems media damage is too great for any chance of recovery.
Users browsing this forum: DanAT and 247 guests
