 Post subject: whatWhat does it mean when my WD My Passport Clicks 10 times
PostPosted: March 28th, 2019, 9:58
Now only does it click 10 times, but it does it in a pattern.
clicks 6 times *pause* click 2 times *pause* clicks 2 times then spins down.
If you disconnect and reconnect the power, it does the exact same thing every single time. It's a 1TB WD My Passport Ultra WDBZFP001BBK-03
Apple Store New Orleans
 Post subject: Re: whatWhat does it mean when my WD My Passport Clicks 10 t
PostPosted: March 28th, 2019, 10:49
Banned User
Mechanical fault with drive, gotta open it up and see the internals of the drive.
PostPosted: March 28th, 2019, 12:05
bad heads. contact DR proffesional person. don't open without a cleanroom.
PostPosted: March 28th, 2019, 15:41
Bad advice!
How would “seeing the internals” help?
Firstly I doubt the OP would know what to look for, secondly he/she wouldn’t be able to fix it, and thirdly it would introduce contaminants and lessen chances of recovery.
PostPosted: March 29th, 2019, 3:52
Drive has most like heads issue and need to be send to decent DR professional if you need data on the drive. The more you power up will make things worse.
Search a member "Luke" on this forum, he can help you on this. if you decide to get a professional opinion, their site is
https://www.recoveryforce.com/about-us/contact-us/
Data Recovery Pakistan
Users browsing this forum: Google [Bot] and 249 guests
