Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: ID 86 84 24 5F
PostPosted: April 11th, 2019, 13:04
I have a Micro Center UFD Monolith that keeps giving me the ID 86 84 24 5F.
I have wired her up a few times and always get the same ID.
Anyone seen that ID before?
 Post subject: Re: ID 86 84 24 5F
PostPosted: April 11th, 2019, 13:16
Show photo of monolith.
PostPosted: April 11th, 2019, 13:32
Here you go.
PostPosted: April 11th, 2019, 14:35
Are you sure if you not mix wires from data channel?
PostPosted: April 11th, 2019, 16:11
or you didn't short the wires on the data bus?
Recover My Flash Drive
PostPosted: April 11th, 2019, 16:32
Checked and all okay.
Not sure I understand?
PostPosted: April 11th, 2019, 16:39
It may be a red herring, but bit #2 is always 1. The other bits change state.
PostPosted: April 11th, 2019, 23:35
I think ID should be 0x88 0x89 0x28 0x5F
wiring looks like correct pinout used.
is this point broken?
Maybe go over the whole thing with microscope and look for any solder bridges or balls fallen onto PCB or cracks.
PostPosted: April 12th, 2019, 0:47
How about ID=0x89,0x88,0x28,0x5F,0x00,0x00
https://www.usbdev.ru/databases/toauflist/ic98/
86       84       24       5F
10000110 10000100 00100100 010111111
10001001 10001000 00101000 010111111
89       88       28       5F
This is what you would get if bit 0 were swapped with bit 1, and bit 2 with bit 3.
PostPosted: April 12th, 2019, 9:59
Franc, yes, mine was a typo. that is a valid ID for a device with 1 bank of 8GB. Tim, what is the device capacity?
PostPosted: April 12th, 2019, 10:16
It is a 16gb chip. But only reads as having one part.
PostPosted: April 12th, 2019, 12:30
Thanks for the responses. Not sure where to take it from here. I have double and treble checked the pinout and it is wired correctly.
PostPosted: April 14th, 2019, 18:11
I am not sure I understand the correlation between the flipped bits and the pinout of the monolith?
What would you guys suggest I try?
PostPosted: April 14th, 2019, 18:18
If I'm right, then you should swap data bit 0 with data bit 1, and bit 2 with bit 3.
PostPosted: April 14th, 2019, 18:20
Many thanks I will give it a try.
PostPosted: April 30th, 2019, 13:06
Deleted, back with more info soon.
PostPosted: April 30th, 2019, 13:45
It was a great suggestion swapping bits, but the new ID (A9 A8 28 7F) shows that swapping D0 with D1 and D2 with D3 actually changes more than these bits. I have studied the code but cannot see any viable patterns.
86       84       24       5F
10101001 10101000 00101000 011111111
A9       A8       28       7F
PostPosted: May 1st, 2019, 17:16
Now it appears that bit#5 is stuck high. :-?
PostPosted: September 8th, 2019, 13:14
I just tried this NAND ID decoder:
https://multi-recovery.com/decoder_beta.php
Found ID: 89 88 28 5F
PostPosted: September 8th, 2019, 23:04
As you aren't really using a LA, the "LINE" name isn't quite right, but call the pads LINE:0 , 3 , 4 & 6.
theoretically, when you ID 89 88 28 5F, you should have it wired correctly. But still not convinced nothing is wrong with the monolith!
24 possible combos:
(pad)  :     (wire D1, D2, D4, D6 from reader)
LINE:0 : 1 2 4 1 2 4 4 2 6 4 2 6 6 1 4 6 1 4 2 1 6 2 1 6
LINE:3 : 2 1 1 4 4 2 2 4 4 6 6 2 1 6 6 4 4 1 1 2 2 6 6 1
LINE:4 : 4 4 2 2 1 1 6 6 2 2 4 4 4 4 1 1 6 6 6 6 1 1 2 2
LINE:6 : 6 6 6 6 6 6 1 1 1 1 1 1 2 2 2 2 2 2 4 4 4 4 4 4
Theoretically you should be able to keep trying wire combos until ID is 89 88 28 5F. If the actual die is not 89 88 28 5F, then I'm not sure what you can do!
still not convinced nothing is wrong with the monolith though. Also, there could well be a change in pin order on the die, making the pinout different but in physical same locations (switching data lines) like we are seeing on some SD Cards
regarding the capacity conflict.. there could be a CE1 and maybe a RB1 as well somewhere, presenting the second crystal
or it could just be stuffed!
